Results 1 to 13 of 16
    New Carrier Infinity Install-Dip switch settings?
    I'm having 3 identical systems installed:
    Furnace: Carrier 58MVPB080-F-1-14
    Heat Pump: Carrier 25HNA936A003
    Coil: Carrier CNPHP4221ATA
    Control: Carrier SYSTXCCUID01
    I noticed alot of dip switches inside the furnace cabinet. I asked the installer if those need to be set, or whether they are factory set, not needing changes. One installer told me that they don't touch those, and that they are set by the factory. That the infinity controller does everything. 45 minutes later, another technician and the other two installers had the cabinent open, looked perplexed, were flipping the dip switches around.
    I'm confused. Any thoughts here?
    Jun 2001
    Louisville, KY
    Once the equipment has been started, the Infinity ignores the switch settings. They are wasting their time.
    Merry Christmas
    Oct 2006
    If you not use Carrier SYSTXCCUID01, than dipswitches setup very critical.
    Dec 2006
    Fayetteville,Arkansas
    But in this case they are using the Infinity UI. So they don't need to set dip switches.
    If you choose not to decide you still have made a choice.
    On the train of consequences there ain't no turning back.
    Houston,Tx.
    Quote Originally Posted by cdh View Post
    .That the infinity controller does everything. 45 minutes later, another technician and the other two installers had the cabinet open, looked perplexed, were flipping the dip switches around.
    looked perplexed? I thought Carrier only used professional Contractors that had to go
    through rigorous training classes to even become a Carrier contractor.
    Are they back to selling boxes again?
    “I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
    The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
    No Guns…No Freedom…Know Guns…Know Freedom.
    Quote Originally Posted by mrbillpro View Post
    Back to selling boxes?
    Certainly not ,like all manufacturers they,
    never stopped!!lol
    Houston,Tx.
    never stopped!!lol
    Well you kind of know what I meant, the person or persons that come out
    should not have been looking perplexed, right?
    True ,but it sounds like at least one guy knew the answer,could have been some new guys.
    cdh:
    Some settings of the DIP switches are used for diagnostic purposes. Laptop is preferred though.
    Jun 2001
    Louisville, KY
    Quote Originally Posted by keepitsimplestupid View Post
    cdh:
    Why would a laptop be 'preferred' with an Infinity control installed on the system?
    Merry Christmas
    Apr 2005
    Tampa, Florida
    Quote Originally Posted by jrbenny View Post
    Because it's about as useful as playing with the dip switches on the Infinity system. 'though you might happen to have product manuals on the laptop.
    Dec 2006
    Likely what happened is when they started up system and the control performed the static pressure check it came back too high. So they thought they could adjust the airflow with the cfm dipswitches.
    Infinity system forces you to consider the current ductwork when you install the equipment.
    I don't think they took the electrostatic 20x20 filter out of the return grill when they hooked up the system. Aren't those type of filters restrictive? Could that have given an alert and led them to make adjustments? Although, I thought it was stated previously that with the infinity controller, the dip switch settings are ignored anyway.
