Results 1 to 13 of 14
Thread: Is this gizmo a preheater
06-23-2007, 07:51 AM #1
Is this a preheater on top of a big boiler?
THe photo is on top of a big ole' boiler at a co-op.
I was wondering what the water lines do at the blue deal.Last edited by The Doctor; 06-23-2007 at 11:07 AM.
It's great to be alive and pumping oxygen!
06-23-2007, 04:03 PM #2
Banned
- Dec 2001
- Southern Tier, NY
- 6,066
not clear ..
installed on the stack..??
economiser, feed water pre heater
06-23-2007, 06:29 PM #3
Try the URL on it's side :-)
http://cannonboilerworks.com/fwh.phpMike
06-24-2007, 07:18 AM #4
Awww, but what fun is that? I can sort through the personalities and characters here, and THEN go the the URL. It's much more fun IMO.
That IS on top of the stack, Slimwoodie. It's on top of a Cleaver Brooks.
It's a CB-LE, which might be the line or type, if that means anything.
Don't mind me, it's just that the boiler is just one of many on site, which just adds to the wonder of it all for me.
06-24-2007, 07:32 AM #5
Banned
- Dec 2001
- Southern Tier, NY
- 6,066
Aaaaahhhhh ..
itsa Stack Economiser ....
carefull of the stack temp, .....on Oil, they can really soot up a C-B
06-24-2007, 07:33 AM #6
Banned
- Dec 2001
- Southern Tier, NY
- 6,066
I assume yer burnin' Oil ......
or ....
that's a really bad lookin' gas fire .....
06-24-2007, 01:14 PM #7
- Feb 2007
- NE Pennsylvania
- 39
how does a stack economizer work and how would i know if i was looking at one.....?
06-24-2007, 06:06 PM #8
A stack economizer is really not much more than a heat exchanger set on top of the breeching before the stack connection. Feed water is run through it on it's way into the boiler. The water is preheated by the flue gas passing over the other side of the tubes on it's way out to the stack. This increases efficiency by used some of the waste heat and allowing the burner to run at a lower setting to maintain the load.
06-25-2007, 10:24 PM #9
So did we. We figured it was bio or somethin.
they're burning natural gas! I hardly believed it until I saw the notes from the tech-- 8" tested on some date was written on the gas piping. It was either 2 or 3" pipe, or maybe it was 2 1/2"or ....
This pic was the best, and it doesn't look real good for the flame, but when you look from the back peep sight the flame has much more blue in it.
The water in the econo. was picking up like 55*. It was leaving at 225* at like 125psi. I was like a kid in a pie shop--thinking again about working for that rep in this area when I visit sites like this.
06-26-2007, 03:28 AM #10
- May 2007
- Centrail IL
- 6
That last pic is of a dual fuel boiler. Oil/Gas.
06-26-2007, 06:11 AM #11
06-26-2007, 05:43 PM #12
- May 2007
- Centrail IL
- 6
We can do our 400hp Cleaver Brooks in a weekend if we have to but we don't get in any hurry. We fire Nat. only and have very good water treatment so punching the tubes and wash out is not to bad. Not sure how bad it would be punching the tubes on an oil fired rig, I never done it, but it sounds like it would be a good time to wear the old uniforms. If you have a lot of refractory to repair it may take longer.
06-26-2007, 06:41 PM #13
Banned
- Dec 2001
- Southern Tier, NY
- 6,066
I .... Like ...Refractory repair ..... $$$$$
