Results 1 to 9 of 9
    obsolete carrier split
    Is here anyone out there that knows where I can find schematics for a
    38ad240620. This is an old split that the Carrier web site dosen't recognize. Downtown Chicago high rise elevator machine room cooling. 22 years old. just replaced compressor. 20 ton carlysle 06e. The shop that was in there before us had 110 lbs of 22 in this beast and slugged the pump. On start up I found a couple of issues besides the overcharge. One bad txv and a bad low pressure switch. Going back there tomorrow with the parts and would really like to have a schematic to see what is supposed to go on with this thing. Any help would be greatly appreciated.
    Philadelphia
    Quote Originally Posted by schomaker9253 View Post
    did you try hvacpartners.com ??
    you may have to register if not already..but its pretty good
    Philly Area
    Scho,
    Email me (my email address is in my profile) and I'll email you the service manuals.
    Hampton Roads, Virginia
    Try these links
    http://www.docs.hvacpartners.com/idc...it/38ad-5p.pdf
    http://www.docs.hvacpartners.com/idc...it/38ad-4w.pdf
    Hope these help
    By the way these are not obsolete, still lots of them around, good strong unit.
    Kevin
    "There is plenty of room at the top because very few people care to travel beyond the average route. And so most of us seem satisfied to remain within the confines of mediocrity." -- Benjamin Nnamdi Azikiwe, first president of Nigeria
    "It's not the customer's job to know what they want." -- Steve Jobs
    Old Carrier 38AD Love um !!!
    Serviced many of these old bad boys - once all the normal mechanical problems are repaired, if you have the money and time, upgrade to electric unloading with non-recycle pumpdown and it will last to you retire.
    clgman,
    Non recycle pumpdown? What is that. Have never heard of it.
    I put a mechanical unloader on the new pump, but with the txv on the first stage coil starving, and a 95* load in the space, I couldn't get the compressor to load up for any length of time. That is a very strong unit. They don't make 'em like that any more.
    clgman,
    Djken That is just what the dr. ordered
    Obsolete Carrier Spilt
    Schomaker 9253
    Non recycle pump down is a control circiut modification that allows the unit to pump down and cycle off on the low pressure control after the thermostat is satisfied, and will not restart until an additional call for cooling is realized. The system does need to have a liquid line solenoid, and accessory relay, etc., to accomplish the wiring modification.
