Results 1 to 7 of 7
    Jun 2007
    Boston
    Confused Looking for Simple Minded SetbackThermostat
    I'm looking for a programmable thermostat for the heat in my basement shop, and I need help finding the simplest model that will do what I want. I've looked at a number of thermostat specs on-line, and they don't typically go into enough detail to tell what would be best. They also usually have a lot more bells & whistles than I need.
    The same program can run every day of the week, and I'd like to program several times (i.e. noon, 6 pm and 10 pm) to set the heat to a low setting. To get the heat on, I'd like a one button over-ride that would kick the temperature up to a higher setting (say, 68 degrees) until the next set time occurs. This way I can easily turn on the furnace when I want to work in the basement, but it will turn the heat back down automatically if I wander off.
    We have a Honeywell Chronotherm upstairs, but in order to turn up the heat, you have to increment the temperature up with multiple button pushes. This would work, but it's a bit of a pain in the neck. I used to have an old clock-type thermostat in my old house with high and low temperature pins, and it only took a single button push to kick the heat up until the next "low" pin came around.
    Does anyone know of a thermostat that would fit the bill? I can always get another Chronotherm & tap dance on the temperature button to kick the heat on, but after years of one-button convenience with my old clock model, I'm hoping for a similar solution. I've tried contacting most of the major thermostat vendors, but haven't gotten any replies.
    Thanks for any suggestions!
    Dec 2006
    Middle Tennessee
    honeywell 6000
    The Vision Pro 8110 is about as simple as you can get but has 7 day programming, override til the next program time.
    www.hotfreshcool.com
    Jun 2007
    Boston
    Thanks for the leads! I went to Honeywell's web site, and they must be updating it or something. I tried to download owner's manuals for both the VisionPro & FocusPro models and got an error both times. Hopefully it work on Monday & I can check them out.
    Jun 2007
    Boston
    Hmm
    Both of the Honeywell thermostats mentioned use the same approach, which requires bumping up the temperature one degree at a time. I was hoping to find something that would allow me to toggle back & forth between a normal and a set-back temperature with a single button push.
    Oddly enough, this feature appears to be available in Honeywell's radiant floor heating thermostats, but not the run of the mill heating & cooling thermostats. I tried looking at a couple of other brands, and they all appear to be the same.
    Unless someone knows of an oddball out there, it looks like I will just get used to hammering on the "up" button for a while when I want heat.
    Thanks!
    Apr 2005
    Tampa, Florida
    Honeywell's commercial thermostats will do this. I know their Commercial VisionPro stat does, I believe it's a TB8220 model #. Just push "override" and it'll automatically go to the "occupied" temperature. Hit "cancel" and it'll automatically go back to the unoccupied temperature.
    SW FL
    Thumbs up
    It does not get any simpler than the HoNeYwell model
    RTH230B at Lowe's for $37
    http://www.lowes.com/lowes/lkn?actio...033&lpage=none
    http://customer.honeywell.com/Techli...0s/69-1800.pdf
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
