Results 1 to 13 of 29
    Jun 2007
    Warranty / Goodman 10Yr & Lifetime
    Noticed Goodman has 10Yr warranty on 13SEER AC & Lifetime scroll compressor warranty on 14SEER & up AC. This sounds great for a manufacturer that I thought was on the low end price wise. What's up? This seems high for the industry. Are they in financial trouble?
    Thanks.
    Florida
    Quote Originally Posted by vrocrider View Post
    Thanks.
    Price means squat. Goodman is vastly improved over the years. The lifetime warranty is high for the industry, many others offer the 10 yr.
    Financial trouble? A company in financial trouble wouldn't be lengthening their warranties. Goodman now owns Amana also.
    Littleton MA
    We just picked up the line and so far so good. I went for a walkthrough earlier today and man that 14 seer unit was really quiet outside. I'm happy so far and with the warranty how can you complain. I did notice the quality wasn't exactly where I am used to seeing the Trane units (fit/finish) but with what the units cost I am not complaining.
    We only want to do it, if we can do it right.
    Some of the cheapest cars have had longer warranties than the super expensive ones.
    Do you think they do that to get more sales,or because they are better cars???lol!
    Sep 2006
    Check out the warrantees on the upped end stuff for ICP (Heil, Tempstar, Comfortmaker and Arcoaire) and York. Nordyne's warranty is one of, if not the best, there is on their IQ system.
    Jun 2007
    The Twilight Zone
    Goodman heat pump warranties
    The 14 SEER Goodman units that use R-22 (the GS line) have a 10 year compressor and coil warrranty. The R410A models (the SS line) have a lifetime compressor warranty to the original owner.
    My 14 SEER Goodman heat pump that I bought from a wholesaler and will be paying a pro to install 6/18 week has a Copeland scroll compressor and a field-installed TXV external to the air handler (the TXV was a few extra bucks but well worth it in my opinion). I chose not to use a variable speed fan in the air handler as I went with the good ole reliable multi-speed fan.
    Jan 2006
    Raleigh, NC
    Thanks.
    If there are 50 brands higher priced than Goodman, then there are 25 brands lower in price than Goodman. Goodman's product has raised the bar in warranty. And, replacement parts availability.
    The primary reason for not installing Goodman was preception/image. At one time we were Heil dealers. Heil's warranty replacement parts were not readily available. We dropped that line.
    Apr 2001
    Thanks.
    These warranties apply only if:
    1) The unit is installed in an owner-occupied, single family
    residence, and
    2) For lifetime warranty coverage on the compressor, the unit is
    installed with a new indoor coil or air handler to which it is
    properly matched by the installer, and
    3) The unit is properly registered with Goodman online within 60
    days after the original installation. To register, follow the
    instructions found at www.goodmanmfg.com.
    Nov 2000
    Eastern PA
    Quote Originally Posted by gary_g View Post
    Where in Baltimore did you buy the equipment from a wholesaler?
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Nov 2000
    Eastern PA
    Quote Originally Posted by Jabarco View Post
    residence, and
    As equipment keeps getting more complicated and has less tolerances due to higher efficiency engineering, manufacturers need to have more control over all aspects of the installation and mantenance. I would not be surprised to see Lennox's concept of owning dealers come back into play with more of the manufacturer's in the next decade.
    Sep 2006
    Quote Originally Posted by RoBoTeq View Post
    He probably bought it from an Internet seller. Can't sling a dead cat without hitting one.
    Nov 2000
    Eastern PA
    Quote Originally Posted by mchild View Post
    Why do you sling dead cats?
