Results 1 to 13 of 15
    Southern California
    Measuring Superheat on a Carlyle 06D system
    I'm working on a transport a/c system using R22 and a Carlyle 06D compressor.
    To measure the superheat, the maintenance manual tells us to place the temp probe next to the TXV's temp bulb.
    That's easier said than done, because that area is very hard to get to (only one hand can fit in there). In addition, the TXV's temp bulb is covered with several layers of insulating tape, which can't be removed without destroying it, due to the strong glue.
    So I need another place to position the temp probe. Some textbooks say on the suction line, 6 inches from the compressor. This would work, but its about 6 to 7 feet away from where the manufacture says to place the probe. I don't know how this would affect the superheat reading (the manual's superheat range is 12 - 18 degrees, with 15 being ideal). Is there a conversion factor I need to use, to compensate for the excess length?
    Apr 2001
    In that case, I would use the instructions "on the suction line, 6 inches from the compressor". Ideally, 20 to 30F of superheat is what you want at this location.
    Jabs
    st.petersburg,fl
    Lightbulb
    Bingo
    Isn't sanity just a one-trick pony anyway? I mean, all you get is that one trick, rational thinking, but when you're good and crazy, well, the sky's the limit!
    superheat
    yes, make sure that you are fully loaded and check 6" away from the compressor and 25 degrees is great!
    If you are checking at the tev sensing bulb you should have 12 degrees.
    Of course the vapor refrigerant will pick up additional superheat through friction as the refrigerant passes through all those turns and fittings on its way back to the compressor, it might even pick up a little solar gain depending how well insulated the suction line is.
    Then if the compressor is outside on a hot day, with condenser fans pulling 100 degree air across the suction line you might have picked up some more superheat.
    now your 12 degrees of evaporator superheat is 25 degrees compressor superheat. maybe 30.
    I like 25-30, I hate changing compressors due to liquid flood back and it is scientifically proven that refrigerant vapor contains liquid at 9 degrees superheat.
    good luck
    Frank
    true knowledge exists in knowing that you know nothing.
    North Carolina
    Quote Originally Posted by supertek65 View Post
    good luck
    Frank
    Where did you get your info on refrigerant vapor contains liquid at 9 degrees superheat, I have never heard this before.
    superheat
    John Clark C.M.
    John Clark is from compressor manufacturers of America, or something like that!
    He wrote the compressor section in the RSES SAM manuals.
    I think he and Wes Taylor the chief engineer from Carlyle are the two big compressor gurus in the country.
    I think John is a very reliable source.
    Frank
    Mar 2006
    Pasadena, California
    superheat
    Never heard of that statement " superheat at 9 F contains liquid". The Carrier 30RB chillers with EXVs run on 7.5 to 8 f superheatentering the compressor. These are design conditions. In that case all scroll compressors would have to be replaced under warranty.
    Friction ?
    Sep 2006
    Ohio
    Quote Originally Posted by 747ken View Post
    What I do is make a small cut in the insulation by the TXV bulb to get the line temperature, then cover the cut with foam tape. As far as the difference in line temperatures at the bulb or at the compressor, I have checked at both areas on the same unit with about 7 to 8 feet of well insulated pipe between the two points and only had about 1 degree difference in temperature. But this is on a chiller where the compressor is in the same room as the evaporator.
    Southern California
    Quote Originally Posted by hands View Post
    That's also a good idea. I'll have to get another temp probe besides my Fluke pipe-clamp type.
    Also, I came across this superheat kit. It might work since my system has a schrader valve right next to the TXV's temp bulb. Anyone use one of these?
    http://www.cdvalve.com/products.asp
    Louisville, KY
    Smile Superheat recommendations @ the Service Valve
    You can find everything you need to know about the superheat at the following link.
    http://www.brainerdcompressor.com/superheat.htm
    Hope this helps!
    Ohio
    good luck
    Frank
    Frank, are you implying that the refrigerant will absorb 13 degrees (25-12) of superheat while traveling thru a "6-7 foot" suction line? I think this is highly unlikely unless that line is running thru a very high ambient.
    jogas
    Mid-west
    The txv companies say there can be liquid droplets in the suction line at superheats up to 6F.
