Results 1 to 2 of 2
    Air Cleaner and Humidifier for bad ducts
    Last year we replaced a 60 year old forced air furnace with an American Standard, 2 stage variable speed. 150 year old house, the downstairs seems to have adequate returns, but the upstairs does not (5 smaller sized rooms, with only 1 return which is in the room furthest from the center of the house). In the winter we have dry dry air, sniffles, bad throats, etc.... We need cleaner moister air and we are thinking of adding an air cleaner and humidifier before next winter (don't ask why we didn't with the new furnace).
    1) Are there suggestions as to which air cleaner and humidifier to add for an old old duct system?
    2) Will the lack of returns upstairs substantially limit the benefits of an air cleaner and humidifier? Unfortunately more returns cannot be added the basement as there are no closets, etc. to drop through.
    Boise Idaho
    get an accu-clean that is designed for trane / american standard units. they also have good humidifiers. honeywell steam is pretty nice.
    I would replace any of the bad duct at the same time especially since you want to add moisture to the air.
    you will want a thermostat with a seperate fan timer that allows the fan to come on on its own independant of hating or cooling modes to "scrub" the air.
    find a good contractor, maybe even call whoever put in your new sytem last year, since they are already familiar
    later, matt
