    Jun 2007
    No oxygen barrier in radiant floor heat
    I installed a radiant fl heat,350ft of pex (no oxygen barrier) ,ran it off gas hot water heater.5 Years later I'm installing a gas hot water boiler for BBHW, taking out hot air.The question is will I have a problem with rust in the new boiler when I connect the low temp radiant heat .I should of used a oxygen barrier but nothing to saying except I was DUMB.The new boiler will be gas,hot water ,150 temp ,3 or 4 zones,mixing valve,pex(with oxygen barrier) and copper.I thought I posted this already but can't find it so I'm doing it again.
    NJ
    If you're concerned about this existing loop buggering up the new boiler, isolate it from the rest of the system with a plate type heat exchanger.
    Ed J
    Rossland, B.C.
    Yes .isolate te rad. loop it will mess up the system if you dont. it will need separate boiler feed, expansion tank, and rust proof pump.
