Results 1 to 13 of 17
    Jun 2007
    Trane residental 4 ton unit fan motor hot
    Ac cut out after a while of running ,I notice the fan motor housing getting very hot and shut down ,change motor 208 1/3 hp 1075 rpm the same thing happen motor getting hot and shutting down the unit with the new motor.
    Houston,Tx.
    Quote Originally Posted by billcoburn View Post
    208volt for residential? 208 Volt is usually 3 ph. I would call a Pro before you end up spending
    more money on parts, so he can trouble shoot the complete system.
    NC
    Quote Originally Posted by mrbillpro View Post
    208 single phase on outdoor residential.
    Jun 2007
    Trane fan motor runs hot
    Ac cut out after a while of running ,I notice the fan motor housing getting very hot and shut down ,change motor 208 -230volt ac 1 ph 1/3 hp 1075 rpm the same thing happen motor getting hot and shutting down the unit with the new motor. I was told by an tech the rpm should be 825 rpm instead of 1075 rpm thanks :confused
    Jun 2007
    ac fan motor cuts out
    Quote Originally Posted by kedalion View Post
    208-230 single phase 1/3 hp 1075 rpm I was told by an tech it should be 825 rpm?
    Jun 2007
    ac cuts out fan motor
    I was told by an pro tech the fan motor is the wrong rpm should be 825 instead of 1075 agree??
    NC
    what is the model number of the unit and I will tell what should be on it.
    Dec 2006
    Middle Tennessee
    if you put a 1075 motor on a 825 blade you will for sure overamp the motor!
    Dec 2006
    Middle Tennessee
    Quote Originally Posted by Airmechanical View Post
    and it will shutdown after it gets hot, until it finally burns out the new motor, if left on that application!
    Jun 2007
    ac fans runs hot
    The unit # is BDW-748A100A0 trane the fan was change about 4 mos.ago by an tech.
    Jun 2007
    Wink ac fan motors runs hot
    [QUOTE=billcoburn;1514593]what is the model number of the unit and I will tell what should be on it.
    The unit # is BDW-748A100A0 trane the fan was change about 4 mos.ago by an tech. this is Information on the new blade 608151101,x38010348020,T12e102238.50cw three different #`s
    Jun 2007
    ac fan shut down
    thanks the trane unit BDW-748A100A0 call for an 1075rpm 1/3 horse I will find the right pitch blade I hope where will i start looking .bill
    NC
    MOTOR; 1/3HP, 200/230/60/1, 825 RPM, 48 FRAME, PERMANENT SPLIT CAPACITOR, SLEEVE BEARING
    This is what should be on the unit. Call a service tech and have it done the RIGHT way. Don't be cheap.
    The fan blade that you have on there now is the original blade for an 825 motor.
