Results 1 to 13 of 13
    Apr 2012
    Charlotte Area NC
    Why flush the line?
    Follow up diagnostic after 2 compressors have been installed, system building ridiculously high head pressure (like almost 650 psig) with a very low suction pressure (read 0)...
    The txv screen was so clogged I ended up cutting the line set adapter out to try and clean it and just ended up replacing the whole txv and adapter all together. Also a new filter drier was installed after I cleared the lines with rx-11 and nitrogen sweep
    Cut in multiple spots to show clog to boss
    Sent from my iPhone using telepathy
    sounds like they added 5 more lbs to get suction up ... bam 650
    Tn.
    Wouldnt be the first time thats been done.
    Aug 2013
    OKLAHOMA
    How could they miss that. lol
    Oct 2013
    Lynnwood wa
    Looks like someone didn't braze with nitrogen lol
    Mar 2009
    Mid-Mo
    Quote Originally Posted by okie1997 View Post
    Because low suction pressure ALWAYS means more gas.
    There are people who live and learn, while others are just livin'. Don't be the latter.
    Northern California Central Valley
    I don't think brazing without N2 would cause that much build up, that looks like a major oil problem. N2 is always a great protocol but how many units have been burned in without driers or N2? And they ran for years.
    I wonder if this was a retro from R-22 to R-410A?
    Sent from my SCH-I535 using Tapatalk now Free
    Oct 2013
    Lynnwood wa
    Quote Originally Posted by rselby View Post
    Brazing without nitrogen can cause is if you have a idiot that has multiple crappy joints. I had a installer that worked at the company I work for use a stick a joint. He caused multiple TxV and filter dryer failures due to him not brazing with nitrogen and not being able to braze. But your right many units have worked for many years without doing it. It also could be from the line not being flushed from a burn out compressor or r22 from the old system. Who knows. Either way no matter how it happened, the guy who installed it didn't do his job correctly
    That is a fact, he didn't do his job. A stick per joint, that's going to be expensive in more ways than one. I sure hope he didn't have any leaks? ;-)
    Mar 2009
    Mid-Mo
    It looks like carbonized oil to me, personally. Did this system have a burnout on the first 2 compressors?
    Oct 2013
    Mobile, Alabama, United States
    How many tanks of oxy/acet did he go through per job?
    Sent from my DROID RAZR using Tapatalk
    Feb 2013
    Cary NC
    Compressor burn outs, no nitro, stick per joint...... Looks like Grandpa's hashish pipe.
    Sent from my GT-N8013 using Tapatalk now Free
    Nov 2007
    California
    I agree, this was definitely caused by an A/C unit with a very bad smoking problem.
    Its parents were smokers and this one picked up the habit at an early age.
    Even after multiple heart transplants, it still never learned.
Quality Home Comfort Awards
