    Chicago
    flowrater or Txv
    I have a customer that tells me they usually leave there a/c set at constant temp all year should I even bother with a txv for this customer?
    Fort Worth, TX
    Are there any performance issues with this customer's system?
    Building Physics Rule #2:
    Building Physics Rule #3:
    Chicago
    I will be setting up a new system for them
    Fort Worth, TX
    Quote Originally Posted by jmiles View Post
    If this is so, then with many new 13 SEER match-ups you no longer have a choice. They will come with a TXV.
    I wouldn't even blink an eye over it. A TXV is just a better way to meter an evaporator, period.
