Results 1 to 13 of 13
    Jun 2007
    21ahba wheatherking
    my freind is helping me licened rheem hp i thought i was getting a rhsa hm3017ja instead they sent 21ahba wheatherking new model from what i read my? it doesnt match the old ruud i have size wise should i stick with the 21ahba or try to get the rhsa3017ja quality wise i know 21ahba is old cabinet some other pros say blower is different and not as good any comments thanks ...........bill
    Grottoes VA
    huh?
    Volunteer State
    Quote Originally Posted by bjsuone View Post
    Since your freind is licened, I'd ask him.
    Nov 2001
    Port Saint Lucie, FL
    The AHBA uses the same X13 motor as the full size air handler(RHSA), the only differance is the physical size of the AHU(and the coil configuration). Rheem(weatherking) was the go-to for the smallest air handler size before the 13 seer switch, after getting blasted by angry contractors...they developed the abha to maintain the 35" size of the previous Rheem RBHA ahu's....and now all is well in the world again.
    Quality wise, there is no differance, I like the AHBA because it will fit anywhere.
    Nov 2001
    The AHBA21(with the correct coil) will work anywhere that the RHSAHM3017 will, there is no differance(that you need to be concerned with) between the evap coils and blower motors in either unit...check ARI if you are really worried about it.
    Jun 2007
    21ahba
    Thanks i guess my biggest problem with this is the 3017 is a perfect match for for my old ruud wouldnt be easer to use the 3017 if i can get one plus i like too see rheem on label why mix brands even though the guts are the same and does it have the n coil i dont want to open box in case they switch out ........thanks again
    I doubt it''s a match. Which outdoor unit do you have? (model#)
    Jun 2007
    21ahba
    Quote Originally Posted by billva View Post
    RPNE030JAZ
    Quote Originally Posted by AIR PRO View Post
    AHBA series do contain the x-13 motor, the -HSA contains a standard PSC motor, not the x-13.
    the x-13 is only found in AHBA/AHBL and UHLA/UHLL series.
    RPNE030JAZ
    Either A/H is a match.
    Nov 2001
    Quote Originally Posted by A/C Frank View Post
    Not in this part of the country they don't.
    Nov 2001
    The perfect match for your old unit only exist's in a warehouse in texas somwhere, they do not make them anymore! The correct thing for you to do is have the condenser/heatpump installed with a new coil/ahu. ..............and have the ducts checked to be sure they can handle it.
    Jun 2007
    21ahba
    just curios but what is this perfect match and why are they in storage
