Results 1 to 11 of 11
    Oct 2005
    Hobart dough mixer H-600T
    I have been trying to take out the broken pin (holds the dough mixing hook) with no luck.Tried almost everything heating it, tried to drill it with carbide drill,WD-40. Checked with vernier caliper its not taper pin. Hobart is not giving any information. Sr no is 99-217-742. Any help will be appreciated.
    Apr 2005
    Central Indy
    you have to remove the plug screw and the two set screws under the plug screw before you can drive the pin out. If you tried drilling it , you may have to replace the agitator shaft Hope this helps
    Oct 2005
    Thanks anyway I did remove both set screws
    midlands of the uk
    dough mixer
    no help from hobart now there is a surprise
    sell you a new one sir !
    There is faith, there is hope and then there is another compressor change
  5. Likes EjBreeze, howerpeter liked this post
  6. #5
    Regina SK Canada
    remove the planetary and press it out. That is the only way that worked for me. remove the oil in the planetary first. reinstall and add new oil.it takes about 6 oz.
  7. #6
    Feb 2007
    Manor, Texas
    use a angle grinder and just slightly grind the part of the pin thats sticking out. then you can get the rest out.
  8. #7
    Mixer Year
    Please pardon the interuption but while you are on the subject, does anyone know how to identify the year of manufacture of a Hobart H600-T?
  9. #8
    Jun 2016
    Does anyone know the easiest way to take out the sleeve of the attachment drive out on a H-600?
  10. #9
    Jun 2013
    South East US
    Quote Originally Posted by filter87 View Post
    I believe there is a very small hole in the bayonet shaft, opposite where the pin protrudes, that you insert a small punch into to tap out the pin, if it isn't too destroyed. I've had to heat the pin up red hot on some to allow getting it out.
    If there's no hole, perhaps I'm dreaming, or maybe I drilled one there. It's been too long.
  11. #10
    Jun 2016
    Thank you very much I will give it a shot!
  12. #11
    Apr 2017
    these things are tough!
