Results 1 to 7 of 7
    Sep 2013
    Confirming the Carrier system installed matches what was agreed to
    Hi,
    I'm building a new home and in the contract we upgraded the AC to be a 14 SEER variable speed/humidity controlled system. The contract doesn't specify any model numbers.
    The buidler has installed the system, but it states that is a 13 Seer unit and I haven't been able to determine if it is variable speed unit.
    The downstairs system model #'s are:
    Carrier FB4CNF018
    Carrier 25HBC318A300
    The upstairs system model #'s are:
    Carrier FB4CNF024
    Carrier 25HBC324A300
    Is there any way this combination of units would rate as 14 Seer?
    Would these units be considered a variable speed/humidity controlled system?
    Thanks in advance for any help!
    Apr 2011
    SE Washington
    neither are variable speed, and the 3 in the model denotes 13 seer, ask to see the AHRI sheet , it will tell seer
    May 2009
    Cumming, GA
    The 018 will get 14 seer with a TXV. AHRI #3698297
    The 024 will get 13.20 seer (at best) with a TXV. AHRI #3698460
    http://www.ahridirectory.org/ahridir...ultSearch.aspx
    Sep 2013
    Thanks for the quick replies! I searched for AHRI #3698460 but didn't find it. I'll be sure to ask for the AHRI sheet after they replace the units to meet what is in the contract.
    Thanks again!
    May 2009
    Cumming, GA
    Quote Originally Posted by shields2001 View Post
    Thanks again!
    My mistakes: the correct # is 3698450. Still only 13.20 seer.
    Thanks again!
    Would it not be better to ask before they are replaced?
    Sep 2013
    Good point. Thanks again for all the help.
Tags for this Thread
