Results 1 to 13 of 15
    Jun 2007
    frymaster filter pump motor change out
    please give me any ideas or indian tricks, i will be changing one out next week.. the pump and motor sit sideways at the far back of the fryer and i can not get to it from the back i have to lay under where the filter cart sets , omg... i have changed out pumps before and that was bad enough.... this looks like a pain in my already sore @#$!!!!!
    any ideas from any one who has done it?
    I would do whatever it takes to pull that unit out and go in from the back.Mcdonalds has to be serviced usually after 12.00am.If the fryer went in there's a way to pull it out.
    Jun 2005
    NY
    post up the model/serial number, if its the one i m thinking of, the entire shelf the motor and pump sits on unbolts so you can work on it a little easier, if i remember right. been a while since i ve done one where the motor isnt on the filter cart
    Aug 2005
    iowa
    the last frymaster i did, part of the back came off. it still wasnt easy but better than laying on your back in all that gack! guess yours could be differant.
    Jun 2007
    thanks
    thanks for the input... i will let you know how it goes.... some days i really like this job.... some days i dont.
    Aug 2005
    iowa
    cmon now!!
    everyday is a fun day!
    say it with me now!
    Jun 2007
    roswell nm
    Post Better You This Time Than Me
    www.frymaster.com/iframe.asp?...
    pull up your fryer and look and see if there are any service tricks you can see
    Jun 2007
    mission accomplished
    got the motor out,,, turns out it could have been worse... fyi....the motor mounts to a cross bar this bar is held on by four bolts they also adjust the hight of the motor so the filter cart will line up ... take them all out and the motor will come out....... wigle wigle etc. un mount the motor and put it all back in .. there is a trick to geting it in i can let you know if you ever need to know it..
    on to more adventures !!!!!!!
    see ya all later .
    Nov 2003
    Wisconsin
    Quote Originally Posted by rluke777 View Post
    see ya all later .
    I work for a McD franchisee and change those things all the time. The only real trick is to use a hydraulic type roller jack to get the new one in place so you're not trying to hold 40 lbs. with left hand and lining everything up with the right.
    Nov 2003
    Wisconsin
    Ditto
    May 2010
    I need to pick up a replacement pump / motor and this one matches my specs :
    Baldor 34G040Y214G1 Frymaster 8261756 motor .33 hp new
    Do you guys think this is a good deal? Cheapest I've been able to find online is almost twice as much. I've never bought anything off ebay before. What do you guys think?
