    Feb 2013
    New Jersey
    univeral control boards
    Hi, we are looking to supply our trucks with a universal control board we understand not all units will accept this board but what is your opinion on the best control board for hot air furnaces, split systems, we are just trying to save space and time
    Dec 2006
    What? Who? Where?
    Honeywell T73500
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Oct 2010
    Austin, TX
    Are you referring to replacements for manufacture circuit board or unitary controls for Building Automation Systems?
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
    Feb 2013
    New Jersey
    control board in hot air furnaces,
    Quote Originally Posted by XcelTech View Post
    Mount Airy, MD
    Quote Originally Posted by electricomfort View Post
    There are some residential universal (listed for many) boards out there. I assume this is what you are referring to?
    This section of the forum is for BAS and the Residential Tech to Tech section maybe able to help you out further should my assumption be correct.
    Should you be trying to tie these systems into a BAS, then we will need more info in order to be able to help you
