Results 14 to 18 of 18
    Jul 2011
    Quote Originally Posted by coolperfect View Post
    It works used both on A/c and refrigeration Years ago I had a hussman 5 door freezer the defrost heater shorted out to evap coil 3/4 Alum tubing used this method cust had the casas another 4years never added another drop of gas. And the best part is I saved this peice of coil in my truck.One day I was at the supply house the guy from turbo tourch was there showing off his alum soulder we made another hole in the coil he could not fix it
    My unit has a leak on the high pressure aluminum condenser coil. Would the clamp made by combining the saddle valves work for this as well? Do you suggest any specific brand?
    I'm looking at this one:
    Links to direct purchase sites is not permitted.
    Thanks.
    Last edited by beenthere; 07-29-2011 at 05:11 AM. Reason: removed link to direct prchase site
    The Hot South
    They sell a repair kit that's a short piece of pipe with compression fittings on both ends. It was designed for the copper to aluminum connection where the coil meets the liquid or hot gas line but I'll bet it will work on a straight section of coil also.
    in a house, Appomattox, Va.
    Trane has two different size repair kits for their al cond coils- GE is Trane now.
    I've used the splice kit to repair one that had a hole rubbed in the line on the bottom. cut out damaged section and rejoined the two ends. That unit was 20 yrs old and they wanted to patch it.
    Col 3:23
    Edited by mod
    As per the AOP Rules only Professional Members * can reply with advice to the OP. Anyone may post and ask questions. They may even question the * member answer but not give advice or expand on the advice given. Please read these rules for a complete understanding. AOP Rules
    For those in our industry who wish to become a Professional Member, please click here and follow the instructions. Apply for Professional Membership
    Jul 2011
    northern Minnesota
    stay brite with the alum flux think it melts at a little over 400*
