Results 1 to 13 of 20
    Any experience with Nordic Pure air filters?
    They have MERV 12 filters of various thicknesses and sizes fairly cheap, with low pressure drops, but I never heard of them until recently. I can't find any opinions or reviews about them using Google (except one, someone complaining about their order getting crushed during shipping). Has anyone used them? If possible I'd like to find out about defects, weaknesses or concerns before I buy a case...
    http://www.nordicpure.com/
    Thanks!
    Sep 2006
    Compare with MERV 11 filters from other suppliers. Same media. Same construction.
    Quote Originally Posted by breathe easy View Post
    Hmm. It wouldn't be the first time MERV ratings were overstated by a manufacturer (3M Filtrete, etc...). It is surprising that MERV claims aren't regulated, requiring certification (like the UL 900 ASHRAE 52.2 certification) with enforcement mechanisms (such as fines for making MERV performance claims without 3rd party certification). I think I'm going to start specifically asking for a UL-900 certification before I buy anything. I asked Nordic, we'll see what their answer is...
    Thanks Breathe Easy!
    Thumbs up they *are* certified MERV 12
    I received this information from Nordic Pure:
    "Test was performed on an assembled filter. The test aerosol was KCL neutralized. " and then named the certification lab.
    That sounds legit to me -- I won't go as far as calling the certification lab.
    I may order a few to toy with and use them during winter, when allergy season is over (I'm sticking to MERV 13s during summer), as they are a good deal.
    Sep 2006
    I guess I am always the skeptic. Just because the test was done by a certified lab does not mean you are comparing apples to apples.
    For example a MERV number should always be accompanied by the air speed at which the filter was tested. I don't see this on their information. I do see a test speed for resistance which is 300 fpm. Other filter manufacturers test at 500 fpm. Generally, the slower the air speed, the higher the efficiency for pleated filters. Hmm!
    You mentioned 3M. Actually, their test results are now reliable. They started off in the filter business playing the same types of games mentioned above. Their early Filtrete entries had MERV 12 and MERV 13 numbers and then the air speed in meters per second in very small print. I think the higher ups at 3M saw what was going on and put a stop to it. For several years they had good numbers with consistent air speeds in feet per minute. Now they have actually developed their own system with their own numbers 1050, 1200, 1400 - whatever that means.
    3m
    thanks for pointing out the fpm effect.
    As for 3M, I was referring to their expensive MERV "12" (purple packaging), which a few years ago was downgraded to MERV 11 (oups! I'm not sure that was entirely voluntary. My bet is that some people did measurements and complained). That made me mad, I felt cheated as I had bought a few based on that claim. I still can't believe that their grade just below (the red packaging) is rated MERV 11 as well, because when I looked closely at it I found big gaps (holes) in the media through which sand could get through.
    Nowadays, if you go to Lowes stores, the 3M Filtrete "advanced filtration" are rated 1700 (as you say, whatever that means). Everywhere else, the 3M Filtrete "advanced filtration" (same packaging except the number claimed) are rated 1500. What's up with that?
    Sep 2012
    Thanks for the info, BE. Very enlightening. I have used Filtrete filters up to 1500 with no obvious ill effects on airflow. Now I use their 1000, because my understanding is that's basically a MERV 11 filter. I've also used other brands from Home Depot or Lowes rated MERV 11 with no ill effects. I prefer the less expensive brands because I don't need nor want anything higher than MERV 11. But lately most stores in my area offer only 3M in the higher MERV ranges, leaving me little choice. That's why I tried the Nordic Pure from Amazon.
    I took note of your comment about their MERV 12 rating. As with so many consumer products, average people tend to assume more is always better. To me, it's bad enough when a company caters to this misbelief. But outright deceipt tells me I need to find someone else to do business with. All things considered, that's how I now view Nordic Pure.
    Feb 2014
    "Each became completely bowed-in as the fan attempted to suck air through the clogged filter." From your earlier post you make it clear that you had too much filter for your system. Obviously, you needed a much lower MERV rated filter. Maybe a flat, non-pleated, MERV 4 or 7? Also, if the filter is "clogged" by particulate, then it sounds like the filter worked very well! I work at NP and talk to customers all day long who think getting a higher MERV means getting a better filter. I always tell them that the higher MERV is only better IF it's recommended for your system. There is no deception on this. As for the the 3M "fpr" system...it's not the ASHRAE 52.2, industry standard "M.E.R.V." 3M came up with it as a marketing device and they will tell you that it is designed to measure filtration for particulate smaller than 1micron. At NP, our air filters are made in Tulsa, OK, and we are very proud of them. We are always available to supply Technical Data sheets or discuss our products. Most respectfully, AMG
    Sep 2012
    Quote Originally Posted by AMG View Post
    These people at Nordic Pure are trying hard to convince people there is nothing wrong with their filters. Their basic claim seems to be that if the filter was clogged, it was working properly. What a load! Their filters clog prematurely because of the crummy materials they use apparently. But the fact they find it necessary to track down online complaints to try to refute them tells me there are many people complaining about their filters. All I know for sure is that I've NEVER had a similar problem with 3M filters. EVER. Not even close. I guess it's like they say, you get what you pay for. Sometimes not even that, as I've learned from reading here on the HVAC forum.
    Mar 2015
    Jackjack, how can you tell whether a filter is getting clogged faster because it's made of crummy material, or because it's working better? I'd expect it was the latter.
    Apr 2015
    I have used Nordic Pure for a few years now. To me if your filter is clogging and bowing in then it is trapping a lot of crap in the air. I do wish there was an easy way to truly know how say the Nordic Pure Merv 13 matches up to the Filtrete 2200/2400. The Nordic Pure Merv 13 seem to use the same filter elements as the lower Filtretes, the Filtrete 2200/2400 is almost paper like, while the NP 13 is more like the lower Filtretes. I have been tempted to,try the NP Merv 14 as that looks closer to the higher end Filtretes, but since you have to buy 6 it is a bit of a gamble if it is too restrictive.
    Apr 2015
    Wow, so glad I stumbled across this forum. I have been have bad "oil canning" noise with my AC for a little while now. I could not figure out why this was happening all of a sudden. At the end of last summer and then again about 3 weeks ago I started getting my filters from Amazon. They are the Nordic Pure Merv 8 pleated filters. Now, they are not to clogged, but when I click on the AC I can see the unit pulling the filter up like crazy like it is not getting air flow through it. I am going to go with a flat Merv 8 (non Nordic Pure) and see what happens. Without a filter (I know I know), absolutely no loud bangs.
    Aug 2015
    canada
    Hello,
    Different people have different views, Nordic Pure manufactures air filters for residential and commercial uses. They are also provide a customer Reminder Service.
