    Sep 2013
    Ohio
    Question Water Furnace Premiere 2 Geothermal Problem
    Wondering if anyone can let me know anything I can do to correct this problem? I have limited funds and am trying to correct this problem? I don't want to call for service if there is something I can fix myself.
    Anyway the A/C fault light came on and shut down our A/C. Since then we have cleaned all the filters - used the shop vac and cleared out the drain pipe - made certain there is no water in the tray. Then we retried the system.
    The air came on and everything was going good. Then about 4 hours later, the fault light was on on the thermostat. I went into the basement and there were little icicles on the panel and they were falling into the drip pan - the drain light and the LG Pressure light were solid red. I turned off the system again.
    Now I don't know what to do next.
    Moved to AOP residential
    You'll need a tech out to find the full problem. And then let you know what it will cost to repair it. Start saving, I don't believe it will be cheap.
Tags for this Thread
