Originally Posted by
Ben44
Read this article that's been floating around the net since 2002 (starting pgs 8):
http://www.buildingscience.com/docum...ntrolling-cost
Am really surprised that a standalone dehumidifier can serve as a good supplemental dehumidification
system with both a reasonable install & operating cost, and that can be readily installed either during construction or after occupancy.
Thoughts on the closet dehumidifier? is it a reasonable alternative to a UltraAire type whole home system?
The standalone residiential dehus are less efficient and less durable but are less investment. You get what you pay. If you want an efficient, quiet out of sight system, add a small whole house Ultra-Aire dehumidifier to a simple a/c conditioner.
Of course noisey residential dehumidifier is better than no dehu.
Regards TB
