Results 1 to 13 of 13
    Feb 2007
    Baltimore MD ( Balimer, Murilyn)
    York Optiview problems
    I'm being tasked to troubleshoot a York Optiview Display on a York YT which will not boot up. Several techs have taken a stab at this before me and they have replaced sundry parts they thought were the cause of the malfunction. I understand the flash memory cards have been replaced twice, the inverter supply has been replaced along with a generic off the shelf display screen and bulb, which I am told is a York equivalent by my stupidvisor.
    I haven't made it to the job yet, but if anyone knows what I should look for on arrival, I'd sure appreciate it. Changing out all the guts in this panel would be a pricey proposition, but may be necessary given the job history.
    HOUSTON TX
    York Manual 160.80-m1(604) Has All The Info On That Panel And Display. Its Avail. Online At York.com
    Feb 2007
    many thanks
    Feb 2007
    Sugar Land, Texas
    Thumbs up
    Make sure all changes that have been are for this machine. York has several different types of boards made buy different people on there optiview. Although same machine, just different manufacturers on software parts. York went with best price at build time on machines. If you continue to have problems with this optiview contact Hans Wile at York Factory in Pa. This guy is supersharp and knows these optiviews better than anyone.
    Titusville Florida
    Have you tried to disconnect all of your boards and see if the watchdog is holding the main board off. Look in my profile and send me a email and i will send you hans phone number
    Feb 2011
    Could you send me Hans Wiles Information, I need help with an optiview panel.
    Thanks,
    Brett Booher
    Booher Industrial
    Booherindustrial@gmail.com
    770-893-7567
    Mar 2002
    Hampton Roads Virginia
    its 2AM.....
    and this board has helped again. i had an optiview tonight that would not reboot after a power failure. after checking all other parts(power supply, boards,)I killed power at the VSD, pulled the flash card, reapplied power, and the damn thing came on. reinserted card and now am waiting for oil temp to return.
