Results 1 to 13 of 126
Thread: Help! Major freon leak
05-15-2007, 10:05 PM #1
- May 2007
- 23
Hi, I started up my unit for first time this year and it was running for about 20 min then made this loud noise like a 'powering down'. Then, we were given the freon show as it sprayed out of the top of the unit for about five minutes! It is a three year old Lincoln 2 ton SEER 10 High Efficiency C/A unit and I'm at a loss. I have a manu warranty but how much is that worth?? Thanks in advance, really...
LizLast edited by missusliz; 05-16-2007 at 12:26 AM.
05-15-2007, 10:08 PM #2
- Apr 2007
- east coast
- 61
better call a contractor in to fix it...more than likely not under warranty unless you bought an extended warranty with it and then it probably only covers parts if your lucky. be prepared to fork out some money its not just gonna be a simple service call....
05-15-2007, 10:11 PM #3
It's not always possible to fix a leak in a coil. Call a contractor to repair, preferably the installing contractor.
S**t or get off the pot!
05-15-2007, 10:11 PM #4
- May 2007
- 23
I called Sears who installed it, and they can't get out until Thurs. Yep, its only a parts warranty from the manu, any idea at how much I'm looking at? I know its $90 just to look at the darn thing...ugh.....I had a burst pipe in my ceiling and I'm just getting the house together from that disaster, when it rains it pours, eh? (pardon the pun...) Also, what could be the cause here? Why doesn't anything last like it used to? My parents got a Hoover when they were married and I was still using it when I was 17 years old...those were the days.
Liz
05-15-2007, 10:15 PM #5
Ohhh that suqs. Not gonna be cheap to fix if the warranty is expired. Get the installer to cover everything possible--don't give in too easily. They should last 15 years or so with few major problems.
Sears hmm, they subcontract most of their installations. Be polite but insist on good service.I believe in latent heat.
05-15-2007, 10:20 PM #6
- Jun 2006
- 491
mam. with all due respect, how in the world would we know what its going to cost you to fix something we haven't looked at? did Sears know? (loaded question there, i know they didn't) furthermore, your join date shows you have just joined this site. did you not see the part about no pricing questions or did you think they were just kidding? sorry but we truly can't answer your question. and even if we knew enough to answer your question, we couldn't answer your question. hope it goes well for you though.
05-15-2007, 10:25 PM #7
- Mar 2005
- Houston, Texas
- 11,644
Read the rules NO PRICING in this forum.
05-15-2007, 10:33 PM #8
- Oct 2003
- 292
Major leak
Seen and heard this many times once while standing over one, I think your compressor is shot. Terminals In your compressor gave up and it will be alittle costly since the lines are sure to be contaminated, probably thru your breaker quickly too? You will want a new compressor, lines flushed,new driers,and vaccumed,also you will need them to return afterwards to replace your driers again to insure a clean system. Told my boss tha,t once and he ignored it since it was his friends, well two weeks later I was back to change them and re-clean the system.
05-15-2007, 10:35 PM #9
Compressor shot? Not likely. Unless they kept running it after the blast. You were kidding, right?
05-15-2007, 10:37 PM #10
05-15-2007, 10:41 PM #11
If it took 5 minutes to blow the whole charge it was probably overcharged and that probably caused whatever that did blow to blow, even the red rag recovery machine is faster than that.
“I am glad that I paid so little attention to good advice; had I abided by it I might have been saved from some of my most valuable mistakes.” - Edna St. Vincent Millay
The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth.
No Guns…No Freedom…Know Guns…Know Freedom.
05-15-2007, 10:42 PM #12
Professional Member*
- Sep 2005
- North GA
- 17,308
Mam, I do not know how forceful you can be, but if it were me I would push Sears for a new unit, at their expense. A unit 'blowing up' after only 3 years is not normal.
It is my opinion that something was probably not done correctly during the installation. But proving that will be tricky.
Best of luck to you mam, you probably will need it.GA-HVAC-Tech
Galatians 2:20-21; Colossians 1: 21-22 & 26-27; 3:1-4; Romans Ch's 5-6-7-8
2 Chronicles 7:14
Quality work at a fair price with excellent customer service.
05-15-2007, 10:43 PM #13
- Jun 2006
- 491
