    Feb 2007
    Rheem furnace specs
    Copying from the specification sheet (.pdf) for Rheem furnace RGFD-07EMCK as follows:
    Input-Max BTUh 75,000
    Heating Capacity Max 72,000
    Input-Minimum 30,000
    Heating Capacity Min 28,200
    AFUE 92.8%
    I was under the impression that:
    Heat input X AFUE = Heating Capacity
    If this is true, then there are discrepancies in the document:
    75,000 X .928 = 69,600, and
    30,000 X .928 = 27,840.
    Also, there are discrepancies listed in other sizes.
    If I am mistaken, please explain how the capacities are calculated.
    Thanks.
    AM
    Nov 2002
    I don't have an exact answer but since no one else is chiming in here's my opinion.
    Every time I question manufacturers on these kind of things/or read on the rules it seems to be a statistic's thingy that the Federal Registry (laws) control. AFUE is a cycling on/off equation that accounts for flue losses while the unit is off and jacket losses where heat escapes while the unit is idle and equations that are derived from the unit turning on and off. The actual running efficiency is different, probably higher. Then a certain number of units have to be tested that each have a different efficiency level when cycling and when running steady. Then you have to statistically average those #'s to say that 90% of the time the unit will be this efficient and deliver this many BTU's.
    If you ask your question with the assuption that they don't know what's up you may be supprised at all the guidlines that are in play here and how often they change.
    Or they made a mistake.
    Oct 2005
    MN
    I don't think I want my Manual J cut so close that this matters anyway.
    Frank
    Feb 2007
    Thanks for the response--makes sense.
    Quote Originally Posted by htrguy View Post
    Actually, looking over the entire Rheem furnace line, there are many 'mistakes'.
    AM
    Feb 2007
    Quote Originally Posted by frankt View Post
    Frank
    Good point, it's not a question so much of cutting it close, but rather to find a unit which will provide what I consider to be a reasonable safety factor over OD design temp.
    Most manufacturers specs that I've seen are either too low (output) or a bit high (this is what they sell), and since none to date was willing to do a manual j, they couldn't back up their recommendation. Had to do my own HVAC-calc.
    Besides, I like the Mod concept. Rep coming today to take measurements (Rheem dealer).
    AM
