    Oct 2006
    lennox XC15 / lennox coil
    we seem to be finding a few condensors that have leaked out all the charge but when pumped up there appears to be no leaks. anybody have same problem
    burlington county n.j.
    not yet
    redlands, ca
    Leaking XC 15
    Had a few leaking at the suction line shut-off valve and one that had a bad weld at the compressor where the suction line comes in. Also, almost all of the Lennox R-410 units we've installed had light oil residue at the high and low pressure switch fittings.
    Nordyne got word from their service valve vendor that leaky 410 valves were out there. We had to change one. Same unit had a leaking low pressure switch. Have had quite a few leaky LP switches on Armstrong pumps.
    THEY'RE ALL JUNK
  5. Likes sparaski liked this post
  6. #5
    Oct 2006
    you would think that these leaks would show up on nitrogen check. does lennox have anything to say about this. by the way thanks for your comments
