+ Reply to Thread
Results 1 to 8 of 8
Thread: UEi C155 - What level of 02 increase to tell if heat exchanger is cracked
    Oct 2009
    Is there a general consensus on how much the 02 needs to rise in the flue gases post blower turn on to point to a cracked heat exchanger?
    Also, has anyone heard of someone using this test on a natural draft furnace?
    A Noisy Compressor Room
    A rise in O2 when the blower starts is not always due to a cracked heat exchanger. Can also happen from other leaks in a furnace.
    Never condemn a HX on the combustion results alone, you need to verify it visually.
    Oct 2009
    Quote Originally Posted by Chuck View Post
    I've thought about this for a while and can't come up with any other pathway for more O2 to enter the flue than the HX. Please explain.
    Air leaks around the vestibule panel on non-sealed combustion units. Also gasket leaks allowing air into the burner box on sealed combustion units.
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by bbuller View Post
    Where there is supposed to be a silicone seal and it breaks down. I have personally never done one but hear goodmans are bad about this.
    I had a few Trane/Am Std furnaces where the screws loosened slightly in the oval ports on the heat exchanger face where the flame enters. Caused a rise in o2 when the blower started.
    To answer your original question, anytime there is more than .5% rise in o2 when the blower starts I am investigating to find out why.
    Oct 2009
    Gotcha. Thanks for the info. It made sense to me that on a non-sealed combustion furnace that you can have all sorts of ways to introduce O2 via the draft hood/box, but it was not initially clear how a sealed combustion unit would introduce 02 in any avenue than the heat exchanger.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
