Results 1 to 13 of 30
    Brazing Copper To Brass
    I have been an A/C teck for over 30 years now but I have always had trouble brazing these tow metals properly. Mostly carrier evaporator coils with worn out compression fittings, i want to back off the nuts and just braze around the copper and brass fitting. Anyone have any good ideas on type of solder and flux?
    brazing copper to brass
    I want to think all of you that posted how to solder these two alloys and it worked just great, you can always teach a tech somting new if he loves his kind of work. Even after 32 years I still have a passion for this buisness and Ive tried other fields but this is the best keeps your mind working, so thanks again for all your great Info.
    Florida
    Did you try the blue rod....(505 I think....)????
    silver....clean...clean...clean....
    I do not have the answer to you soldering question. I have the same problems you do. I have used a brazing rod with limited success, on steel to copper.
    Quote Originally Posted by vet View Post
    ???It worked and no one gave you any answers?? was this a trick question?
    brazing
    I posted this the other day, sorry but I got back into the wrong form i think. 45% silver with white paste flux, but I had to use the brazing tanks the propane tank just was'nt enough. Ive never done it before except with a brazing rod which was a disaster so thanks again. Boy that silver solder was 45.00 for only about 10 ft. So the other tech looking to solder brass to copper it works great.
    use nitro and the brazing isnt a n issue..(as much)
    Jun 2006
    Las Vegas,NV
    just read this silver solder with paste is the only way and also it has too be clean connections
    Jun 2000
    WYO
    95/5 with flux.
    never say never
    Smile brazing with 45/5 & white paste flux
    I hav'nt tried the 95/5 is it less costly since the silver with flux worked so well, and yes you are right clean,clean,clean! It was really easier than brazing I could'nt believe the results,so thank you all very much.
    strength of the joint
    Silphos brazing alloy is ONLY for copper to copper connections.
    For brass to copper or steel to copper you need the high silver content solder with flux. I haven't tried any of them, but there are other products on the market reputed to be up to the job.
