Results 1 to 13 of 23
    Measuring Humidity Levels
    As a maintenance person, all my units are fixed orifice, 1.5- 2 ton units, split systems.
    To acurately measure the charge and determine superheat I know I should be
    using a sling phychometer to determine wet bulb temp in an apartment.
    Is there any way to fake it ?
    For example if the weather report determines the humidity level in the area,
    is there a standard rule you can use , for example outside humidity + 5 percent more of humidity to determine inside wet bulb, or is this just rediculus ?
    4H: Hot, Humid Houston H.O.
    There must be some professional quality instrument which will deliver humidity conveniently and accurately. I understand the sling psychrometer is traditional and accurate, but it sounds like a bit of effort to use.
    I'm a homeowner who likes to monitor %RH using cheap thermometer gadgets from Walmart. Convenient but not all that accurate, I'm thinking you need something of quality about 10x more expensive.
    Based on my humidity measurements, I can most definitely promise you that outside humidity +5% has no relation to what's going on inside my house.
    Hope this helps -- Pstu
    NW burbs of Detroit
    Quote Originally Posted by summerblues View Post
    A sling is a pain to use for varying reasons. The biggest is you must take a whole bunch of reading and average it out if in a large area.
    Try the Yellow Jacket site as well as Testo.
    For 80 bucks you can buy an electronic hygrometer (fancy name for a RH meter)
    No u can't fake it. You either use the relevent data required or you take a SWAG.
    Ohio
    Wrap a wet paper towel around the end of your thermometer.Then put it in your return air grill.Try it, it works!
    How accurately?
    NW burbs of Detroit
    Quote Originally Posted by BigJon3475 View Post
    How accurately?
    Dig it.
    Fort Worth, TX
    Get you one of these:
    A temperature/humidity stick. The probe is small enough to insert easily into a supply plenum while doing capacity checks. Measures temperature, humidity, and converts to wet bulb. I have one on order from National Comfort Institute. It's made by Testo. Last night at my RSES chapter meeting a fellow tech showed me his and it is the bee's knees.
    Building Physics Rule #2:
    Building Physics Rule #3:
    NW burbs of Detroit
    Quote Originally Posted by shophound View Post
    [IMG]http:// Last night at my RSES chapter meeting a fellow tech showed me his and it is the bee's knees.
    ok i wont ...
    Fort Worth, TX
    Quote Originally Posted by hvaclover View Post
    ok i wont ...
    Sheesh...get your mind out of the gutter, dude.
    NW burbs of Detroit
    Heh, yeah.
    wconell Guest
    Bee's have knee's?
    I shouldn't have slept thru biology!
    NW burbs of Detroit
    Quote Originally Posted by wconell View Post
    Bee's have knee's?
    Yeah and crickets have ears in their shins!
