+ Reply to Thread
Results 1 to 20 of 42
Thread: 30 + 30= 60??
    Jun 2013
    South Caolina
    30 + 30= 60??
    I need a 60 capacitor, of course guess what we are out of... Is there any way to use jumper and hook 2 of my 30 caps and get them air til tomorrow when I get my delivery?? May be a dumb question but... Thanks for the help
    Dec 2012
    columbus, OH
    Simply wire them in parallel.
    Jun 2013
    South Caolina
    Thanks. I figured maybe I could but wasn't willing to fry something on a guess
    Dec 2012
    columbus, OH
    P.S you should apply for pro membership. Im not sure if I shoulda said that in open forum.
    Jun 2013
    South Caolina
    Ok, thanks for the tip. They can move the thread if need be, you are probably right
    Jun 2013
    South Caolina
    I will do that. They can always move the thread as you are probably right.
    Jun 2002
    south jersey
    There are some good capacitor vids on here if you get pro membership. Also some good ones on you tube.
    You need to put the phone down and get back to work!
    Jul 2010
    North Myrtle Beach, S.C.
    Where are the vids on this site?
    Quote Originally Posted by Core_d View Post
    And in the Pro forums there are threads that tell you how to figure out what your uF will be if you wire them in series.
    Not allowed to apply for pro membership until you have 15 post.
    Dec 2012
    oklahoma
    question on the subject. i was told when you parrallel two capacitors they must be the same uf .
    example 10+10=20 . said you couldnt put a 10uf with another uf rated cap such as a 5uf? is this true?
    Jun 2013
    N. Canada
    Quote Originally Posted by jeffinok View Post
    No.
    Dec 2012
    columbus, OH
    Your start caps is parallel to your run cap before being taken out of the circuit.
    Apr 2002
    Dallas, TX
    Quote Originally Posted by IRBH View Post
    No.
    The math is simple either way... Add them up.
    If we have data, let’s look at data. If all we have are opinions, let’s go with mine. – Jim Barksdale, former Netscape CEO
  14. #14
    Jun 2013
    South Caolina
    Thanks for all the help and tips today. Once I get to 15 posts I will "go pro "
  15. #15
    Phoenix,AZ
    Why don't you experiment with your meter! Wire 2 in parrallel and then in series! Then read the MFD with your meter! Simple and removes all doubt and i'm sure you could come up with all kinds of different combinations!
  16. #16
    Dec 2012
    oklahoma
    thanks for the replys.
    i know in series what ever two you combine halves it . just wanted to make sure i could mix and match uf ratings in parrallel . again thanks
  17. #17
    Jun 2001
    Yes 2 30's in series gives 15uf but doubles the voltage rating. It gets more complicated when caps are different values.
  18. #18
    May 2013
    The cap calculate is just opposite with resistor
    Resistor in series:
    R total= R1+R2
    Parallel:
    R total = R1 X R2/ (R1 + R2)
    Calculate the capacitors:
    In parallel:
    C total = C1 + C2
    In series:
    C total = C1 X C2/ C1+ C2
    For example:
    if you hook up 2 caps in series (c1 = 5 uf, c2 = 10 uf)
    C total is = 10X5/(10 +5) = 3.333 uf
    The total value alway smaller than the smallest of the 2.
    3.33 uf < 5uf
  19. #19
    Jan 2011
    Portland, OR
    parallel=plus
    series=subtract
    and yes, verify with a meter.
    easy peasy.
  20. #20
    Southeastern Pa
    Quote Originally Posted by 54regcab View Post
    In theory, the voltage tolerance would add.
    That's all for an open forum.....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
