Results 1 to 9 of 9
    Aug 2011
    Heat Pump Control Wiring
    I am installing a new Luxaire Modulating Furnace for one of my customers. He has an existing older 38C Carrier heat pump, two piece unit with the compressor unit in the basement. I am looking for information on wiring this to the new Furnace. From the heat pump section in the basement to the Furnace I have R, G, C, W2, W3,. I am looking to find out where the W2 and W3 wires should go on the new Luxaire LP9C Furnace. There is a O terminal on the new furnace board along with all the standard terminals, Thank you for any help
    Aug 2011
    Carrier Heat Pump model is 38SQ
    Jan 2006
    Near Atlanta, GA.
    So your gonna have 2 duct systems? Or are you installing backdraft dampers at both units.
    Jun 2001
    Can you hook it up using a dual fuel thermostat or a heat pump kit?
    Aug 2011
    It already has the heat pump thermostat there. I am thinking I just need to put the G wire from the heat pump onto the Y terminal on the furnace to ramp up the blower for cooling. The W3 terminal should go to W on Furnace to bring on Heat.
    Jun 2001
    You need to have a means of shutting off the heat pump when the furnace is running.
    Delaware
    Compressor unit in basement? Should that not just be a cased or uncased coil? Get yourself the honeywell 8000 stat. Thats all you need with out a fossil fuel kit. But...he must have a fuel kit alredy. did you notice what he had? But that stat makes it easy.
    Always here
    Quote Originally Posted by energy star View Post
    Yep, on that model. The outdoor is just a remote condenser.
