Results 1 to 13 of 16
Thread: Scotsman cmc256
    Aug 2013
    Scotsman cmc256
    How to troubleshooting the main control board
    Oct 2012
    Where we mow our own grass
    CME256?
    Has the CM3 control, any question in particular about troubleshooting the board?
    Aug 2013
    Hi mike. Yes like if it is any way to find out that the problem is the cm3 and not any of the components ( sensors, water pump, compressor, etc. ) like a test that confirms the main control board is good?
    Aug 2012
    willowick ,oh
    what is the machine doing or not doing.
    Aug 2013
    At first the ice machine turns on but it was no water pumping so I changed the water pump and clean the eyes at the float sensor and i also clean the water temperature sensor. The unit starts but I can hear the fan coming on and off and about 5 minutes of freeze circle it shuts off again with diagnostic water light blinking. Any clue of what is wrong. Will appreciate any help
    Southold, NY
    Aug 2013
    I did all that ( clean, freeze, harvest ) and still shutting off after 5 min of freeze circle. How can I test if temperature sensor, float level sensor and bin full sensor are good or bad ?
    Dec 2010
    Woodbridge Twp, NJ
    If you're a tech, you'd be able to use the service manual that pecmsg provided.
    Every customer you take for granted today will be someone else's tomorrow.
    Chicago, IL
    I fixed one that had the same problem about 3 months ago. Pump relay on the board was bad. It was a friday night and I didn't have a board. I broke open the controller, broke open the relay, and cleaned the contacts. My intention was to make it last through the weekend. Its still running.
    Aug 2013
    No. I am not a tech. Thank you Craig1 can you tell me were is locate the pump relay at the board? Will appreciate it
    Aug 2012
    willowick ,oh
    Quote Originally Posted by MiguelCh64 View Post
    dont do it.
    Aug 2012
    willowick ,oh
    just dont. call someone to fix it right.
