Results 1 to 13 of 15
    Jun 2009
    South Carolina
    SMAN4 SYNC QUESTION
    One of our techs has got the SMAN4 and SDP2.
    I did the new firmware today for him on the sman4. And got it to sync up to IDWB on the SMAN
    But is there a way to manually enter ODDB or a way to read ODDB without getting a wireless transmitter?? While using the SDP2.
    Jun 2009
    South Carolina
    Now when i turn it on
    IDWB says NSC.
    and ODDB is blinking
    but i cant get it to switch back over to IDWB or get ODB to read on them per the instructions. Took the batteries out to try and reset and no go
    Any ideas
    Oct 2008
    Fullerton
    Quote Originally Posted by klee7013 View Post
    IDWB says NSC.
    Any ideas
    To reset the wireless connection do the following:
    Put it in Target Superheat Mode (IDWB, ODDB)
    Press Sync
    Leave it searching until it auto powers off (5 min)
    Once you set it up it wants to stay synced to the last thing it was synced to, to make it easier. But sometimes if you switch it gets stuck searching for the last thing. It will "forget" it using the process above.
    Russ
    Jun 2009
    South Carolina
    Thanks Russ. Got it to work.
    Oct 2008
    Fullerton
    Great! Glad you got everything working again.
    Apr 2013
    Independence, MO
    Russell, am I understanding it correctly when the sman4 syncs, it has to sync to both to remain on wireless connection, so it can't remember to sync only the outdoor dry bulb while you manually enter the indoor wet bulb? I own all the wireless stuff including the hg3 and sdp2, but currently use only the aat3 to get my indoor wb, then plug it into my sman4, most usually because of dirty feet syndrome after washing the outside unit. It would be nice if I had the time to go back in to retrieve my sdp2, but our company loads us down with slow devices and paperwork. Time to chase is difficult.
    Advice is always free, but keep in mind free does not mean it's always right.
    Feb 2005
    question for Russell, I want a sman4 and sdp2 so I can sync wet bulb, what do I need to sync oddb,or do you just enter it manually
    Jun 2009
    South Carolina
    You can enter ODDB manually and sync the sdp2 for IDWB. Took me a while to figure it out but it is doable. once you figure it out it is easy to do.
    Russ that would be a quick easy video to do because the instructions can make it kinda of confusing.
  9. Likes Kilroy238 liked this post
  10. #9
    Feb 2005
    ok thanks
  11. #10
    Jun 2016
    How do you sync and input the ODDB
    What was the solution? How do you sync IDWB via SDP2 and manually input the ODDB?
  12. #11
    Jun 2011
    michigan
    Quote Originally Posted by mjvickers View Post
    It's not designed to do that. I can't remember if I got it to do it or not. I had the wireless outdoor reading wich is very inconvenient compared to how Imanifold does it from the manifold with small sensor.
    I believe I would manually enter outdoor temp into manifold and when it would want you to enter indoor wet bulb I would just change the manifold back to super heat and wet bulb mode . Then would since indoor sdp2. Very inconvenient and then got target superheat on screen.
    Manual says if you want and one wireless then they both have to be wireless.
    And you have to unplug k plugs when entering Temps manually. Then plug them back in after leaving manual input mode.
  13. #12
    Jun 2011
    michigan
    Much faster to buy the wireless transmitter and ath4. Less P. I. A.
  14. #13
    Sep 2014
    I also had this problem where the idwb would blink and I can't switch to sync oddb. I'll try this solution.
    I like the jl2 and the reports it gives. Worth the money.
