    3 ton or 4 ton compressor
    my house is a 1700 sqft with 13 ft vaulted ceilings in half of the house.A dealer wants to set me up with a 4 ton furnace w/variable speed 4 ton coil and a 3 ton compressor wouldnt a 4ton compressor be the better way to go?
    Fort Worth, TX
    Neither is better if there's no data to back it up. Without a heat gain/heat loss calculation performed, your dealer is just guessing. Find someone who understands the Manual J process.
    Building Physics Rule #2:
    Building Physics Rule #3:
    Some brands require the 4 ton indoor coil, to get the rated SEER of the 3 ton outdoor unit.
