View Poll Results: If it was your house, what do you go with? Oil or Propane
- Voters
- 20. You may not vote on this poll
Yes, Oil burners are more efficient
9 45.00% -
No, Propane is the way to go today
11 55.00%
Results 1 to 13 of 17
05-03-2007, 07:25 AM #1
- Jan 2007
- 18
New Construction: Oil vs Propane-Pros vs Cons of each
My boss is building a new home and is considering the pros and cons of both Propane and Oil heat. He would also like to have cental air. He is trying to determine which would be best for him. The house will be in Plymouth MA.
Anyone want to debate the pros and cons of both? Thanks.
05-03-2007, 07:58 AM #2
- Sep 2006
- 1,253
Oil produces about 140,000 BTU's per gallon to propanes 92,000. In my area there is little difference in price so oil is the way to go.
I'm having the two systems in my home re-done and when complete it will be cooled with heat pumps, primarily heated with heat pumps, and an oil fired boiler will provide supplemental heat to the heat pumps through hydronic coils. The boiler will also provide for domenstic hot water.
Unlike a duel fuel set up where the heat pump is locked out and not used below a certain point (often about about 35*), with this setup the heat pumps will continue to operate and provide heat with the hot water supplementing just as electric strips would. Heat pumps are far more efficient than any fossil fuel heater. Even down to single digits many heat pumps can still produce twice the energy in heat that they consume in electricity. Of course, the electric rates in your area will be a factor.
Good luck.
05-03-2007, 07:58 AM #3
not a whole lot of difference between propane or oil from the homeowner's standpoint. Have to deal with local fuel supplier, keep the tank full and get regular service. If building a new house, I would put a high-efficiency electric heat pump at or near the top of the list of options. Carrier Infinity series or Trane XLi series. Properly sized and installed, either one of these systems will heat a home as well as oil or gas, but (in my area anyway) would be significantly cheaper to operate. And the air conditioning is included.
05-03-2007, 10:22 AM #4
I personally would go with Propane.
for a couple of reasons: first LPG is WAAAAY cleaner than oil and second the tank is outside, and you can bury they tank in the ground ( okay, were else you would bury it )
Oil should be maintained at least twice per year, LPG, because it burns so clean requires less maintenance. But this is really a non-issue for me
Either way, the price of fuel ain't going to go down anytime soon so I would look at efficiency and the go from there. I have never heard of a 94% efficient oil burner, but I don't see much oil around here.
GOVERNMENT
The only parasite dumb enough to kill it's host
05-03-2007, 11:02 AM #5
- Sep 2006
- 1,253
I'm not trying to argue with you but here is my rationale.
While propane may burn cleaner a properly set up oil burner should be clean. A 94% efficient propane burner will give you about 86K of usable BTU’s. An oil burner will give you about 120K BTU’s at about 85% efficiency (can find them as high as 87% - non condensable). That’s about 40% more usable BTU’s per gallon of fuel. I’ll take slightly less clean for that much more output.
I have propane on my property too and if the price were to shift to the point that the net cost of usage BTU's for propane were to be loswer than oil then I could switch over to it. My oil tank is outside but I'm farther south than the OP.
05-03-2007, 12:27 PM #6
no argument here
I'm a NG & LPG guy, I HATE OIL..........literally, the stuff (smell) makes me ill
and like someone all ready pointed out, an electric furnace with a Heat Pump maybe a better option? But that would depend on how much the OP's is paying for a Kilowatt of electricity.
good luck with whatever decision you make
GOVERNMENT
05-03-2007, 12:35 PM #7
i also HATE oil and will never have it in my house. i would go with a propane/heat pump system.
05-03-2007, 02:22 PM #8
Member
- Sep 2005
- 115
As a homeowner who grew up in an oil-heated house, here's another perspective. If you go propane, you most likely will also use a gas (LP) water heater. Plus, LP will be available should the wife prefer a gas cooktop or clothes dryer. With oil, you will mostly likely have to rely on an electric water heater. I know oil water heaters are available, but they are rare and subject to frequent maintenance.
All of my relatives that initially heated their homes with oil have all switched to propane over the years. My biggest concern with LP is the explosion hazard, if there is ever a leak, as LP is heavier than air and accumulates in low areas like the basement.
05-03-2007, 08:41 PM #9
05-03-2007, 10:44 PM #10
- Mar 2007
- massachusetts
- 7
oil heat is competitive!
With oil heat you choose who delivers your fuel
In our area most LP companies own the fuel tank
which does not permit shopping for fuel.
In MASS many many oilheat proffessional serviceman
2 times a year to service is 1950s. Do you really think
most homeowners would pay to service the burner twice a year?
Most burners don't even create soot/carbon anymore.
Trying thinking about hot water heat, nice on a cold
New england night. good luck
05-03-2007, 11:15 PM #11[Avatar photo from a Florida training accident. Everyone walked away.]
2 Tim 3:16-17
RSES Certificate Member
AOP Forum Rules:
05-04-2007, 12:40 AM #12
oder is an issue with some of my customers and the cost of propane is another. what ever is decided mybe they need to look into a duelfuel system
I dont warranty Tinkeritus
05-04-2007, 07:55 AM #13
- Feb 2003
- 1,996
LP has advantages
if you can put in an in-ground 500 gl (or maybe 2) tanks. Fill up off
season. I just still prefer oil because of the safety. You get a double wall
tank in the basement, no issues. Of course a chimney is a must. In ether
case, I would get a boiler with indirect HWH. Do a bit of radiant flooring in the kitchen and bath with panel rads for the rest of the house. Maybe supliment the air handler with a small hydro coil so I could humidify and do fresh air exchnage.
