Results 1 to 9 of 9
    Central Oregon, paradise on earth
    Who here works on gas fireplaces?
    I'm wondering if where I live is one of the gas fireplace capitals of the world. I do maintenance on about 1 gas fireplace for every 3 gas furnaces. Do any of you other techs work on many gas fireplaces?
    Jan 2006
    Powell River, BC, Canada
    Up here on the (liquid) Sunshine coast we've got alot of built in f/p's, inserts, and free standing units and they seem to be getting more popular every year. Prob. 1/2 of all RNC we do have a f/p. With our relatively mild climate a gas f/p is often enough for most of the fall/spring seasons.
    Where are you? Are you done yet? I got ONE more call for you.....
    Here it gets pretty cold and gas fireplaces are mostly for looks. Mostly just people with expensive houses have them.
    By free standing units, do you mean gas (heating) stoves?
    Jan 2006
    Yep, freestanding gas stoves. Just put in a Hampton H-15 the other day. Cute little unit, but all enamled cast iron and *%&*^ heavy!
    Some of those freestanding gas stoves are not only really heavy but also hard to open up to service
    Mostly I service just frou-frou units. Pretty gas fireplaces. And there are a lot of them here.
    I believe in latent heat.
    S.E. Pa
    Cool wrong forum
    Should have posted in the Fireplaces forum
    BTW, gas direct vent stoves put out a lot of heat and are heater rated. Maybe the ones you service are undersized or oversized, high heat loss spaces in a cold climate.
    Welcome to the wonderful world of hearth products!
    Hearthman
    Put out a lot of heat but not very efficient? Just the pilot light's gas costs about $15 per month, and they only dream of 80% efficiency? Well I am still working on the "correct forum" thing.
    Yes i didn't find the fireplaces forum until now. Thanks, hearthman.
    Jan 2006
    OY- alot of units around here that are >5yrs old are decorative, not heater rated, but still put out a fair ammount of heat. Like Hearthman said, the DV freestanding jobs really pump out the heat! Depending on the install they can be a real PITA to service, mostly removing the blowers for cleaning. Some you have to pull the back right off, and they are often against a wall with just the minimum clearance to combustables. A set of right angle screwdrivers are a requirement!
