Page 1 of 5 12345 LastLast
Results 1 to 13 of 54
Thread: Duct lifts
    Duct lifts
    What type of lifts do you guys use for equipment?
    No more Genie lifts. Ridiculously heavy and too bulky.
    We will be using it for raising, up to 5 ton, condensers or air handlers on high platforms or ceilings.
    Has anyone heard of Vermette Machine Company? They have "one man" movable lifts. It weighs around 220 lbs. Can lift up to 500 lbs. 12' high, and come with 10" wheels. They have a couple different models that range in different heights and able to raise up to 1000 lbs. All are extremely lighter than Genie or Sumner.
    Thanks.
    Get back to work.™
    Feb 2005
    Miami, Fl.
    I have the 758T that I purchased from United Refrigeration. Best money I ever spent.
    SW Florida
    We have used the Vermette since I became a SMW a long time ago. the weigh about 1/50th of those damn genies. IMHO they also outperform the genies.
    We also use this for working the band iron into hangers and belly bands. (bohn-combi)
    Quote Originally Posted by arpa View Post
    It's heavy.
    How many people do you need to move that around?
    Get back to work.™
    SW Florida
    1 man easily can move it around. Up and down stairs 2 guys. the masts are removable also
    Quote Originally Posted by zzonko View Post
    I've been looking at three different models. All are lighter than anything else I've seen.
    Get back to work.™
    burlington county n.j.
    we have 2 of the lifts that look like the vermette lift. one of them we have had over 25 yrs. only thing we have done to it is replace the cable once and welded plates on the mast sections to make them easier to knock apart.
    I'm gonna get this one. The 6515.
    Specs are just about exactly what I'm looking for when it comes to weight (219lbs.), capacity (650lbs.), and height (15').
    And for under $1500, can't beat it.
    Get back to work.™
    SW Florida
    Thats a good one. You will come to love it
    Rapid City, SD
    I used to use them all the time... I love duct lifts... so many uses!
    Not that I recommend doing this.... but if you make an attachment to hook a hole hog up to the crank pin, it makes them even easier to use! Course, it can tear stuff up too... so be careful.
    I wish we'd get a small one where I work. Another guy and myself almost took a dive off 10' ladders trying to hang a furnace.
    Mar 2002
    Beautiful British Columbia
    I use a Genie material lift, for duct work and air handlers.
    GO GREEN HEAT
    Howell, Michigan
    I have one of those, paid $50.00 for it at a garage sale, the lady was glad to see it go!
    I was jumping for joy!
    Nov 2000
    Coastal Georgia
    We use the SLA 20 Genies. It's expensive, it's heavy and it ain't for sissy's
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
Comfortech365 Virtual Event
