Results 14 to 26 of 26
    Aug 2013
    Pennsylvania
    i agree with all solutions here. i personally like to make the ice into managable chunks to remove it faster. works for everything. hot water is best.
    Quote Originally Posted by crackertech View Post
    Mine is from harbor freight and will last through 3-4 big trash cans before tripping on ol.
    Overload is probably bad....
    florida
    Educational forums are open.
    florida
    Or there isn't one.
    Tucson, Az
    I'm working on a set up now that I think will work. I've got a 30 barrel will have a dip tube in one "Bung" with a quick connect for a hose that I put together.In the other smaller bung, a connection for a "air hose".
    Fill the drum with hot water and pressurize with constant C02 or nitrogen pressure.
    Hose is set up with a spray handle.
    Jim
    Tucson, Az
    Keeping the Ice Cream Frozen!
    Oct 2008
    Quote Originally Posted by demidos89 View Post
    Chunks...yea, that's how I do it. After settling in to the hour-long or so task at eating away a terribly iced up coil - just YOU, your pump-up sprayer and that ice...it becomes almost therapeutic. I've been told I need therapy anyway, so that must be good...
    Quote Originally Posted by market-tech View Post
    Ya know, I've had a similar idea brewing for spraying leak soap and coil cleaners...
    Or there isn't one.
    Scary thought.
    At least the water would put the fire out.....
    Aug 2013
    Pennsylvania
    theres a sizzle in my barrel TURN IT OFF!!
    oh your screwed and you will know it
    when you reach and try to get it
    sing to the later part of if your happy and you know it lol
    Vancouver , BC
    Garbage can full of hot water and use a little hose and siphon it out. Works great. Beats running back and forth with multiple buckets. I like the idea of a pump though! Don't risk taking a drink of garbage can water haha
    Oct 2011
    Chicagoland Area
    When I did supermarket work, it was the responsibility of the store to de-ice.
    Jan 2010
    Toronto,Ontario Canada
    depends.
    freezer run the defrost thaw in no time.
    coolers run the fan and wait
    Grab a spray bottle from ur local store and fill hot water and spray the hell out of it. it may take long but it gets it done safely
    * i use to torch it... but after a few times i noticed that i burnt wires and caused more pain for myself. running the hot water is the best*
    Get er Done!
    Do what has to be done
    when it has to be done
    as well as it has to be done
    And doing it all the time.
    Aug 2013
    Pennsylvania
    Im surprised no responses to the "theres a sizzle in my barrel" what gives?
