Thread: Air handler fan
    Jun 2013
    Air handler fan
    Ok, so my air handler started making a noise the other day. I shut it off, then wiggled the fan a little. When I turned it back on, it was fine for a few hours. When the noise came back, I investigated a little further to find the small bolt that tightens the fan to the shaft loose, and tightened it. It seems the fan was rubbing against the side. Now that that bolt is tight, the fan makes no noise like normal, until it shuts off. The last couple rotations of the fan seem to rub on the side. I tried to loosen, reposition and retighten the fan, with unsatisfactory results. It seems there is extremely little room to slide the fan along it's shaft. Anyone have any suggestions? The unit is only a few years old, installed back in 2009.
    Jun 2013
    Canada
    Call in a qualified Tech and he/she will have it fixed in no time, be very cautious when tinkering. You can actually cause more harm then good sometimes and it is dangerous. Call back the company that installed it. Good Luck.
    Jun 2013
    Quote Originally Posted by RACMT View Post
    Thanks, I was hoping to avoid that, but maybe I should.
    Oct 2002
    Plano, TX
    Check all mounting hardware, brackets etc. I would replace blade if it had been rubbing. Easy to be unbalanced.
    One thing leads to another. an unbalanced blade will ruin motor bearing
    Tallahassee, FL
    Good news is all parts should be covererd by manufactures warranty.
