Results 1 to 7 of 7
    Jul 2013
    Converting Horizontal Coil to Vertical upflow?????
    Hi all...
    Long story short...
    I fired my contractor for multiple screw ups at my expense. One of his screw ups was getting the wrong Evap coil.
    He purchased a horizontal coil when i need a upflow coil... Can i get the upflow drip pan to convert it... or am I S.O.L.?
    it is a Bryant Evap coil # CNPHP3617ACAABAA
    http://www.docs.hvacpartners.com/idc.../cnph-05pd.pdf
    any help would be great
    thanks
    Northeast Ohio
    I don't believe that coil is convertible. When you hire your new contractor he may be able to exchange that coil for the proper one provided it has not been brazed in yet.
    DEM
    Sorry What heater said.
    Jun 2007
    Round Rock
    What's the serial number on it? I'm curious, because that is an older style coil. Where it is ACAA, the C stands for Copper. The next ones that don't leak have a T for Tin. Now they are all aluminum, I think they are ALA or something. I haven't paid much attention to the new model numbers since I don't deal with them much anymore.
    I like DIY'ers. They pay better to fix.
    Jul 2013
    Thanks for the replies... not really what i was hoping for, but i suppose i will try the exchange route...
    I will post up the serial number later, when i get a chance.... IIRCC, the MFR date was in 2010????? maybe 2011
    Jun 2013
    NORTHERN
    Quote Originally Posted by Bastard- View Post
    Hi all...
    Long story short......
    thanks
    Appears could exchange for their common convertible seen before. NO? Call a distributor and ask for another and a couple dealers, I believe.
    Process cooling: NO COMPRESSORS Earth-Coupled since 1996
    ... however, much still needs to be hybridized energy transfer.
    CLOSED LOOP 2015 listed EER's
    even 49+ now; and "blended from low to high variable speeds" for 32deg.F ~ E-Star
    Perhaps you need a 32F Chiller/HW-Heat: buy a GEO-T Heat Pump (GHP with Heat-Recovery)
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    http://www.hydro-temp.com/products.html and Bosch/Carrier and AquasystemsInc.com
    Jul 2013
    the serial number is 0610x38523...it has copper tubes,not sure about the fins. they look to be tin????
