    Jul 2013
    ducting question
    Hello there. I am new to this site and is currently adding to our house in california, bay area. I am not an HVAC expert but do need some feeback in regards to our HVAC ducting.
    We are adding on a second floor on top of our garage and an office space next to the garage. The second floor consists of a bedroom and bathroom. The furnace is located in the garage right under the bedroom. The HVAC contractor ran 14 inch circular main truck duct above the garage. There is a 10 inch flex duct to service the second floor and the 14 inch steps down to a 9 inch then to a 6 inch servicing the office. My husband wanted to increase the ceiling height of the garage by using rectangular duct between the floor joists. Our HVAC contractor refuses to do that mentioning that the sizes for the rectangular duct needed to fit between the floor joists will be too small and will not provide the amount of air needed for the spaces. My husband claim instead of one main truck line, he can run multiple rectangular lines that service each space, which will provide enough air supply as well. He insisted that the HVAC contractor just don't want to do hard work and just looking for an easy way out. Any feedback and ideas are most certainly welcome.
    Stongsville Oh
    There may be to much in the joist spaces that would not allow for rectangular duct runs. Things like electrical boxes, water lines, drain lines etc. Some times these things look easy until you actually have to do it. It sounds like your HVAC people are on top of the duct sizing issue and want to be sure airflow is not short changed. You may want to get another opinion. Be careful though there may by someone out there that says they can do it without the proper research. Along with the duct being installed in the joist space insulation will probably be needed also which will reduce the rectangular size creating a need for more runs than you think.
    ckartson
    I didn't write the book I just read it!
    Jul 2013
    Ducting Question
    Quote Originally Posted by ckartson View Post
    Thank you! Yes - you are correct. There are water supply lines and also we do indeed have to insulate between the joist as well. I like to get a second opinion and unfortunately my husband is from a DIY family and my in-laws are also mentioning that our current guy is not putting enough thought into it. I am trying to get myself educated so I can obtain my second opinion without getting tricked.
