    Oil Pressure Cutout control
    I need the external wiring diagram Form 3646 for JCI P45NCA-12. Is there anyway of getting Install/Service Literature of JCI's site?
    Aug 2000
    Under my tree
    Yes.
    Nov 2005
    This is the closest I could get right away.
    http://cgproducts.johnsoncontrols.co...F/12011012.PDF
    If not close enough, then you should be able to find what you need here.
    http://cgproducts.johnsoncontrols.com/default.aspx
    Hope this helps
    IlovemyjobIlovemyjobIlovemyjob....say it with me now!
    I got hold of a vendor who set me up with a number to JCI, called and got help right away, and I was able to down load the info. All on my own time. What a day, I'm the only HVAC tech on the job, between the 30 year old unit I'm trying to rewire and the nuisance calls couldn't get anything done.
    houston
    when in doubt jump it out
