Results 1 to 13 of 21
Thread: Scotsman CME256
    Scotsman CME256
    Greetings all! My first post here (I'm kinda new at this).
    I've been asked to look at our church's ice machine (a Scotsman CME256). I pretty much a novice at this but feel obligated to look into it. Here's what i was told.
    1. The water diagnostic light is flashing twice
    2. The unit can be reset and it will produce one batch of ice but after that, nothing.
    I checked the inlet water valve flow and it took about a minute to fill up a small styrofoam cup (8 oz?). It seems to have just a trickle. I check the inlet screen and it's clear. I do not see any other restriction in the line.
    My question: Does it sound like the valve is the culprit? Not being an expert on these things it seems to me there is maybe enough water in the reservoir for one batch of ice but after that the flow is so slow it is not filling up. If anybody can comment on this please do.
    Thanks!
    Check the level eyes and clean it with Q tips and ice maker solution
    Monmouth Junction-NJ-USA
    If you really know how it works, you have an execellent chance of fixin' er up!
    Tomorrow is promised to no one...
    Thanks atoz, I will take you up on that.
    Also, I did check the link rayr suggested an it indicates the inlet water valve should fill an 8oz cup in 3-4 seconds. The water flow coming out of our valve is nowhere close to that.
    One other thing I forgot to mention. I've been told the solenoid at the valve is making a horrific buzzing sound. I personally have not heard it. I guess I'm gonna have to spend more time on this.
    Thanks!
    The inlet H20 valve should between 20 with no more than 80 psig through the valve. Do you know incoming water pressure at your church ? The next thing to to check for residue or small solids that can get by the 80 mesh screen and lodge above the seat and collect in the spring assembly closing off water flow. There are 3 screws to remove after you pull the valve out. If its clean and you have proper power to the solenoid, then replace the valve.
    FEN
    Phoenix,AZ
    If equipped with water filters when was the last time they changed them?
    Toronto
    Is it the water or the refrigeration light that is blinking? Two blinks of the water light means the reservoir didn't fill fast enough. The refrigeration light blinking twice is no ice sensed during harvest. From your post I suspect it is the water light so check water flow at the inlet to the solenoid valve. If there is good pressure then it will be either the water valve, the fill sensor, or the control board.
    I'll need to ask on the water filter...not even sure if there is one.
    They tell me light was the water light and it was blinking twice, that's what led me to suspect the valve. I was not sure how fast these things are supose to fill up...the water exiting the valve is just a small trickle.
    I'm going up there tomorrow and check out everybody's suggestions. Also, I see that I can retrieve the last 2 codes so I guess I'll do that as well and see if it is indeed the water light that is flashing.
    thanks again!
    WI
    I used to work on ALOT of scotsman's. Basically its going to be 1 of 2 things.
    No water pressure (blocked water filter) or faulty water solenoid inlet valve.
    If you cant check water pressure take the water line off back of machine (after closing the water valve!) and try draining it into a bucket. It should flow very quickly into the bucket.
    Philadelphia
    there SHOULD be filter,if there is and there are scotsman or generic equivilent,you can pull the filter out and there is two o-rings on the top of the fiter cartridge,you want to remove the second,smaller o-ring and re-insert the filter,it will bypass the filter and you can tell if that is the problem or not...you cannot have less then 20psi on a scotsman on fillup,it will never fill quick enough,yes rayr is correct,you shold fill an 8oz cup in 3-4 seconds,that comes from scotsman tech support themselves..
    Jul 2003
    Upstate SC
    Dont get sucked in like I did!, When working on this machine and running it with the lid off you can produce a second (false) problem of no harvest, meaning the harvest light wont blink enough and it will shut down after the second batch!
    The bin lights are light sensitive!!!!!!!!! had one factory tech support had me order and replace the eyes to find out nothing was wrong, second guy jumped right on the issue and got me going!
    And all the other guys seem to be right on the problem with the water! also scotsman tech support is 24 / 7 now!!!!
    Well, problem solved.
    Before replacing the water valve I checked the actual flow before entering the unit. Surprise!!! almost no flow. Appears there was a lot of crud in a couple of places upstream. Blew that out and had a strong flow of water. Ran machine with the old water valve and it was better but still not filling a cup in 3-4 seconds. Went ahead and put on the new water valve and got the flow I was looking for. We're making ice now.
    I appreciate all the good advice and suggestions from the forum. This was good experience and as fun as ice machines are, I think I'll stick with working on motorcycles for a living.
    Thanks!
    Well, hold on there cowboy...I just thought it as fixed. Last night before I left i sat thru 2 batches of ice. I thought all was well. Today someone at church said there was no ice and the off light was on and now the refrigeration light was blinking twice. Seems this is a harvest error. Can anyone provide me with some additional insight?
    Thanks!
