Results 14 to 26 of 26
    Jul 2013
    Quote Originally Posted by SBKold View Post
    No its not Mr bill. Hes right its a muffler.
    Well, if I can lift the top high enough tomorrow (and get the wife's cooperation to hold onto it, I'll see if I can get a mirror on it to read the label. I thought it was a drier, but what do I know <shrug>.....
    Jun 2013
    jeddah, saudi arabia
    Additional infractions may result in loss of posting privileges.
    30GTN150
    Aug 2001
    Pavilion, NY
    The location is in the hot gas portion and a drier would never be placed there from the factory. The bends in the line between the compressor and the reversing valve are factory made and would not be in that orientation if it was not there to begin with.
    Jul 2013
    Well, I was able to read the label and it says.....MUFFLER....
    So my own ignorance and inexperience led me to believe that there were two driers when only one exists in the system......
    Thanks all.....
    Quote Originally Posted by branded View Post
    Thanks all.....
    You are not the first to have thought that, and there will be plenty more with the same assumption.
    Atlanta GA area
    Thanks all.....
    X2...
    Many a person employed in this business make that mistake...
    Keep that unit clean and it will run for you for a while longer.
    GA-HVAC-Tech
    Quote Originally Posted by ga-hvac-tech View Post
    X2...
    With the exception of York I know of no other MFG that installs a dryer in the discharge side of the compressor.
    Houston,Tx.
    Who cares anymore, he found out it was a muffler, is there still something the OP needs answered here? Read my sig. "Mistakes are proof that you are trying" of course this don't apply to all, some don't make any mistakes.
    Jul 2013
    No Bill, I've got all my answers....I at least like to have a cursory knowledge of what's 'under the hood' in case this thing does decide its had enough...I at least know where the run cap is and the contactor and defrost board and so on.....
    Tallahassee, FL
    That rust on top of the compressor is a sign that it is running hot and IMHO would not be a bad idea to have checked out/serviced/check superheat/subcool.
    Jul 2013
    Well, I haven't actually measured the temperature of the top of the compressor (what would be 'hot'?) but I have checked the sub cooling myself and it's around 10 degrees which is what its supposed to be.
    It also sounds 'normal'.....I'm a big fan of not fixing what isn't broken (yet), especially given the age of this unit.
    A scroll compressor (new Copeland 5 ton 61k BTU) would cost around $1k and the installation labor costs, having to take down the system, recharge and so on tells me that I don't want to mess with it right now.
    Delaware
    looks like a beach in there, lotta sand
    Always here
