Results 1 to 13 of 26
    Jul 2013
    Question Two Driers? One internal and one external?
    Hi, I have just moved into a new home and am now 'learning' my systems. Funny how when you buy a car you get a 'phone-book' sized instruction manual but when you buy a home you get the keys and nothing more, LOL....
    Anyway, I noticed on my Carrier 5-ton Heat-pump/AC condenser unit outside that I have an external Drier on the liquid line. I can see (looking through the fan from the top that there's a drier still installed internally?
    Why would a tech not remove the internal Drier if he intended to add one externally? Is this common practice?
    Thanks again
    Aug 2001
    Pavilion, NY
    While multiple driers are frowned upon as they can cause excessive drops in pressure,, if the system is otherwise functioning properly I would not worry about it. The one in the unit itself is factory installed and the installer may have opted to add eon without knowing there was one. If the system is opened for whatever reason, that would be the time to remove both and install 1 new one. It would be counter productive to remove it on a functional system in my opinion.
    DC Metro Area (MD)
    Are you sure it isn't a discharge line muffler? They can tend to look similar. Can you post a picture of what you're looking at?
    As for an internal drier, does it appear to be factory installed or field installed at some later point? I could be wrong, but I believe Carrier has shipped the drier with the outdoor unit (field installed) for quite some time, at least the past several years, so if there is one installed internal to the unit, it was added at some later point. And yes, when opening the refrigerant system it is best practice to remove the existing filter drier and install new.
    I think Ryan is right on this one.
    Jul 2013
    I assumed it to be a drier as it's on the liquid side and it does appear to be factory. It appears to connected between the reversing manifold and the compressor with a pipe that resembles a p-trap.
    I'll see if I can shoot a pix although I'll have to lift the fan to see.......
    Jul 2013
    Well, here's an attachment (I hope)....
    Aug 2001
    Pavilion, NY
    It's a muffler.. That unit looks pretty ancient. The compressor terminal block cover is missing.....let a sleeping dog lie
    Jul 2013
    Well, the house was built in 2002 so unless they installed a used condenser somewhere along the line my guess is that it's around 10 years old.......
    Houston,Tx.
    Quote Originally Posted by kangaroogod View Post
    Its a drier, someone probably change the coil and instead of recovering and taking the internal drier out, they just pumped the unit down and installed a new drier at the coil.
    Tallahassee, FL
    That compressor looks like its running Hot.
    Side question.....what made you think about 2 driers? Are you in the industry?
    Tallahassee, FL
    No its not Mr bill. Hes right its a muffler.
    Houston,Tx.
    Quote Originally Posted by SBKold View Post
    Looked like a bi flow drier, but I could be wrong, we have probably 100 HP's in Houston, so not to good with them.
    Jul 2013
    Hot? There's some paint missing from the top and some still on the sides (of the top).....Just looks like weather related wear to me.
    I have done (*sigh) my share of auto a/c repairs over the years....I'm no expert but I am fairly savvy about refrigeration systems, at least to an extent that's many times more than your typical homeowner.....
    Edit: Oh, the wiring cover I knocked off by accident. It's back in place now.....
