Results 1 to 10 of 10
    Sep 2012
    New York
    When is good practice good practice ?
    So went on a call of a 6 door traulsen refrigerator not cooling. Upon arrival compressor off condensor fan running. Cooled compressor tried to restart it off on thermal.. Check start cap found no good ordered one. Would you recommend replacing start components I mean from trying to start for who knows how log would it be good practice to change them?
    May 2008
    Kansas
    All
    I never change a start cap without changing relay. I figure the relay sticking is the most likely culprit and callbacks are expensive
    Mike
    Mar 2013
    Quote Originally Posted by mikeweber3 View Post
    All
    Mike
    x2
    Oct 2012
    Wisconsin
    I always replace all start components as a set (start capacitor, current relay/or potential relay, run capacitor - if equipped, and overload - if external and replaceable).
    I also carry an assortment of 3in1's and universal relays, and amrad turbo start capacitors and run capicators, to get by in a pinch, in case I don't have the oem start components with me.
    Sep 2012
    New York
    Yeah that's what I figured just wanted to check with you guys to get your take on things... Yeah this place had about four other fridges so they could do without this one.
    Jan 2013
    florida
    six door ? 3 on each side, or in a row ?
    Jan 2013
    florida
    Quote Originally Posted by yaytech View Post
    by the way, change all start components when one is in question...
    Oct 2011
    Chicagoland Area
    Always. Sometimes, supply houses will have everything but the overload. In that instance, unless there is visible damage to the overload, I would leave it in. Also, make sure the cpr is set correctly on the Traulsen. It's possible that it contributed to the death of the start components.
    Sep 2012
    New York
    This refrig didn't have one, they are most common on freezers if used at all no? I've never seen on on a refrig
    May 2010
    Canada
    I see em on dual temps and self contained units.
