    Honeywell ign. module
    Anyone seen the honeywell s86 spark ign module with the ECOM plug? The module is black. It's on a new Lincoln X2 oven. Really giving some intermittent ignition problems. Can't get a good microamp reading through ground. Was wondering if there is a tool to plug into the ECOM plug. Lincoln says no.
    south cental texas
    yes there is a special tool for this. middleby marshall has a technical service bulletin about this. the part will cost $80 and you need it to read microamps. honeywell changed it's ignition modules 3or 4 months ago,and you will need this to adjust combustion blower microamps.
    Thank you very much for info!
