Results 1 to 13 of 21
    Jul 2010
    NJ
    Proper or improper usage of flex duct
    I have a friend who is doing a major renovation of a commercial space. The contractor has installed flex for all the take-offs. The flex ranges from what looks like 8" diameter up to 16" diameter. The runs of the flex look like between 15 and 20 feet each where roughly half of that is horizontal then there is what looks like 2" fiber cloth straps that hold the duct where it drop 90 degrees down to where the outlets will be. I told him these sharp 90 degree bends are restricting the air flow significantly and he should talk to the contractor. I saw him today and said I bet the conversation went like this: "a friend told me this what do you think, and the reply would be your friend does not know what he is talking about". He said yup he asked both the contractor and the architect and both said I am wrong. So, what do you pro's think, is this acceptable or should he insist that they install galvanized elbows where they make these 90 pinch turns in the flex or some other option. Thanks for your input.
    Dec 2010
    In our area, on a commercial job (with a permit), we can not run over 6' of flex on a supply. There is a reason for this..................I'm just saying.
    Jul 2010
    NJ
    George2 - thanks. He told me they told him it meets code here (which surprised me), but I am just looking to help him understand if he should have them change this to eliminate the restrictions caused by the pinching of the flex at these tight 90 degree drops.
    Memphis
    If he had enough slack in the flex he could pull the flex up a little and strap it to make the curve a little less harsh. That would be a very inexpensive improvement. I didn't say its a ideal solution but it'd be better than just leaving it like it is.
    Life is like a jar of jalapenos. What you do today might burn your ass tomorrow.
    Dec 2010
    Quote Originally Posted by kirbinster View Post
    When we run flex to a diffuser, we'll use a 90 degree elbow at the termination point to assure that it'll never knick.
    May 2009
    Cumming, GA
    I use the flex elbow supports. They're called "Flexright".
    This is what your friend needs. See the link below.
    http://flexright.net/
    Tallahassee, FL
    The inner radius of the bend should be no less than equal to the diameter of the inner flex.
    mississippi
    its 5 feet here. and 90% of the time a hard elbow must be installed on the grill
    Oct 2012
    Where we mow our own grass
    If its any consolation, around here flex is real common. I've seen buildings done in all flex, and runs of flex over 25' long.
    I'm not advocating for flex, however. I prefer metal ductwork whenever possible.
    Quote Originally Posted by George2 View Post
    Funny thing is. The IMC has no reg against flex duct.
    Southeastern Pa
    If an architect and the GC don't care, this is a losing battle.
    Drop it.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jul 2010
    NJ
    Quote Originally Posted by timebuilder View Post
    Drop it.
    Yes, but the customer is the one that ends up living with the problematic installation not the architect or GC.
    Southeastern Pa
    And that is the structure your friend must live and work within.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
