Results 1 to 13 of 28
    Virginia
    coolers rotting out evap fins
    is there any way to stop this ?
    Im told its because of the acid in tomatoes and other veggies ..
    Mar 2009
    Mid-Mo
    I have heard this also and got no solid answer, so I'm eager to hear what everyone thinks.
    Apr 2008
    Bemidji MN
    Tomatoes, onions, anything pickled (it's the vinegar that does it), jalapeρo peppers and anything salty also. Mix any of these vapors with the condensate that collects on the fins and it turns to hydrochloric acid most likely.
    Oct 2011
    Chicagoland Area
    Tell the customer to not store food in the coolers. Or better yet, tell the mfgs to build coils the way they did 20+ years ago.
    Jan 2010
    A coated coil will slow the process down.
    Oct 2011
    Chicagoland Area
    Unless Delfield makes it
    Oct 2008
    Quote Originally Posted by 2sac View Post
    Hey! But Delfield was part of Manitowoc's grand buy-up when building their conglomerate about five years ago - covering their reach-market. Kolpak (less the now defunct McCall line) & RDI does their walk-ins.
    Usually prep tables are first to give out. If they'd cover their pans tightly, they could probably save themselves a bunch of the green they keep covered in the cash register.
    Virginia
    I wonder if keeping everything in plastic containers with those plastic lids would do the trick
    Only thing is .... most like the steel ones , then merely add plastic wrap , like ^ he said
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by Snapperhead View Post
    I'm going to say no. I used to do a lot of work for Taco Bell and TGIF. The R22 coils that we replaced the R12 walk in coils with would start leaking in as little as 2-3 years. The replacements were either Bohn or Larkin. EVERYTHING in the TB coolers was sealed. I believe fresh produce affects the coils less than processed produced. BK uses fresh produce as does our independent deli's, and they would get 5+ years out of the coils before they started leaking.
    Jul 2012
    Western KY
    I'm with 2sac. Used to get 10+ years out coils. Now you have to order a replacement with the replacement.
    May 2011
    Spring City, Pennsylvania, United States
    Olive bars are hell on coils and power heads too, as already said I was told its from the acid.
    Oct 2013
    Moncton,NB,Canada
    Prep tables are definitely the worst, I find and replace so many evaps in sandwich tables it's crazy. Keeping the unit clean helps a lot, I pulled a piece of bacon out of a coil last week, was frozen in the ice on the coil. Not a good example of keeping things clean, good example of why the start to leak.
    Adam
    Winter Haven, FL
    Had a fine Italian restaurant that would grill a bunch of chicken, put it on sheet pans and roll it under the evaporator. The coils lasted 6 months. We replaced three sets before they fired us for not being able to make the coils last longer.
