Results 1 to 9 of 9
    Feb 2005
    ALC SE6104 and SE6104a
    what is the difference between the two modules?
    Amarillo by mornin'
Size:  12.7 KBName:  sea.PNG
    SE6104 SE6104A
    It's the inputs. The SE6104A and SE6166 use the same pc board , but the SE6104A is just minus all of the components for the extra UI's and AO's
    "It's not that I'm smart, it's that I stay with the problem longer”
    Albert Einstein
    Dec 2006
    What? Who? Where?
    Terminal blocks. SE6104a have the newer small green terminal blocks, where two inputs shares a common. SE6104 have older black terminal blocks which have a common for each input.
    kontrol out
    "Good" - Jocko
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora Watch it here!
    Feb 2005
    thank you
    Hopkins, South Carolina
    ALC discontinued the SE6104 and replaced it with the SE6104a. My understanding is they did this so the layout would be similar to some other modules and they could do away with one of the set-up's in manufacturing.
    This recession won't be over until we raise a generation that knows how to live on what they’ve got.
    Feb 2005
    thanks
    Jan 2012
    California
    Circuit board change to support the expanded se6166 with one format. The a indicates the revision. One board two modules.
    May 2009
    I must say I'm not a fan of the smaller green connectors on the a and zn modules. Seems they are going in the right direction for future designs according to the ALC share site.
    Scott Jalbert
    WebCTRL ninja
    AX and Smartstruxure newb
    The S in IoT stands for Security
    Jan 2012
    California
    Quote Originally Posted by MaxBurn View Post
    They were *****ed at at the dealer meeting by several including myself!
