    New Johnson Program
    has anyone used this program yet? I think its called CCT or something like that.
    Oct 2006
    What do you need to know? CCT (Controller Configuration Tool) is the new software for the FEC/IOM Bacnet MSTP product.
    CCT is the Controller Configuration Tool. Think of it as an HVAC-Pro application that can be used to program a DX-9100.
    It's for the FEC BACNet line of controllers that uses a "question and answer" programming method. I can program a VAV box, Packaged Rooftop Heat Pump, and even a Chiller/Boiler Plant.
    The CCT along with SCT and the NAE Points Schedule can make setting up a network pretty painless.
    It's not all fun and games, but you can crank out a fairly complex network and control strategy in a morning using those tools.
    Being a Johnson product... it's not perfect and there are still bugs to work out. But it is a very powerful tool that has a lot of potential. Just wait for the next revision...
    "has anyone used this program yet? I think its called CCT or something like that."
    It works great. I think it will replace hvacpro. Its alot like using gamespy.
