Results 1 to 7 of 7
    Oct 2006
    upgrade a H.W. AX from 3.4.43 to current ver
    I have a question I am running an older jace with 3.4.43, and with the newest java issue out there I need to do an upgrade on the jace. I am planning on upgrading to the most current version, witch I believe is 3.7. I am running a Lon network with Spyders (pul6438s) to be exact and I am also using Distech ECC-301 controllers. I am not worried about the Distech because it was programmed in Lon Watcher then discovered into Webs, The part I am a little worried about is the Spyders I know I will have to install the current spyder jar but will I have an issue with the older spyders. I have not yet had the pleasure of having to upgrade a jace yet so I'm not for sure what I am in for. One nice thing is I do not have a large database I only running about 10 controllers in the building. I also have a Trane LCI card on a chiller.Any suggestions, or any issue's of doing this would be helpful.
    Thanks,
    Connecticut
    We have been having a horrible time with the java patches and upgrades. My advice to you would be to roll your customer back to java update 17 and lock him there for now. We have had issues with Spyders not working correctly, tuning policies getting blown out and lots of other nuisance problems. Just my
    Jan 2005
    Quote Originally Posted by The Reaper View Post
    I second this. The migration process is not as easy as they would like it to be.
    If you are going to tackle it be sure to copy the old station to a pc then migrate it into the current version of the software. Unplug the jace and use the pc as a soft jace. Test everything with the pc and only when you are happy that all is good commission the jace. Some of the strange anomalies that happen in the logic can be fixed by doing a delete followed by an undo (control Z) and re downloading. Be sure that you use the commission, download, bind, replace sequence on all spyders. The replace fixes a lot of problems as well. As always before you walk away do a system verify report and be sure it is clean.
    Good luck, with only ten controllers it shouldnt be too painful.
    "It's always controls"
    Pawtucket, RI
    3.7 will still not work with the latest java 7_25. Use 7_21.
    Jan 2002
    Fort Worth\Dallas, Texas
    Quote Originally Posted by jcipaul View Post
    Yes it will, you just need the updated jars for Web, Baja and Fox.
    Go Rangers!
    Jan 2002
    I have done several 3.4 upgrades without any real problems. I did have some major problems upgrading a 3.5 station. If you do it, I would do clean dist install on the jace of the existing version after you have backed everything up and verified it from your laptop. Then commission your jace.
    Go Rangers!
    Jan 2002
    Quote Originally Posted by lwarren View Post
    3.7U1 at least
    Go Rangers!
